Suspension & Brakes Theory, alignment, spring rates....
Do Koni Yellows have any advantage over Illuminas besides ride height?
Old May 26, 2005 | 07:32 PM
Junkyard2000's Avatar
Default Do Koni Yellows have any advantage over Illuminas besides ride height?
I have gc coilovers and need some new shocks. I already have the height adhustability but will the illuminas be able to handle the spring rates? If i get konis they'll cost about 150 more plus ill need to get the koni sleeves from gc
Old May 26, 2005 | 09:45 PM
JohnnyWash1's Avatar
Default Re: Do Koni Yellows have any advantage over Illuminas besides ride height? (Junkyard2000)
Assuming you have the OTS spring rates, the Illuminas will work just fine.
Old May 27, 2005 | 07:26 AM
00R101's Avatar
I don't know what GC spring rates you have. But assuming they are the typical street setup (<350lbs) then you should be ok with the Tokicos. However, the Konis will give you several advantages.
1) Koni range of rebound adjustment is much larger than Tokico - see the shock dyno thread the the top of this forum
2) Konis are rebuildable/revalveable/customizable
3) ALmost everyone knowledgeable on this forum agrees that Konis are a better bang for the buck then Tokico (even though they cost more - the handling improvement is enough to warrant the expense
Get the Konis - but make sure you have the right GC setup to use them - you may need to buy an adapter from GC
regards,
alan
Old May 27, 2005 | 10:08 AM
bad-monkey's Avatar
Default Re: Do Koni Yellows have any advantage over Illuminas besides ride height? (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what GC spring rates you have. But assuming they are the typical street setup (&lt;350lbs) then you should be ok with the Tokicos. However, the Konis will give you several advantages.
regards,
alan</TD></TR></TABLE>
Old May 27, 2005 | 11:38 AM
be.twenty's Avatar
i dunno if the illuminas click or not during adjustment but the yellows don't click.. they allow for a more precise adjustment..
Old May 27, 2005 | 11:49 AM
idriveadelsol7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote"> If i get konis they'll cost about 150 more plus ill need to get the koni sleeves from gc</TD></TR></TABLE>
what is that?
Old May 27, 2005 | 12:09 PM
be.twenty's Avatar
Default Re: Do Koni Yellows have any advantage over Illuminas besides ride height? (idriveadelsol7)
GC created a koni specific coilover to sit right on the clip perfectly.
Old May 27, 2005 | 05:23 PM
Default Re: Do Koni Yellows have any advantage over Illuminas besides ride height? (shogun-dc2)
yea i think ill go with the konis. Anyone know where i can get some neuspeed konis for cheap?
Old May 27, 2005 | 07:35 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkyard2000 &raquo;</TD></TR><TR><TD CLASS="quote">yea i think ill go with the konis. Anyone know where i can get some neuspeed konis for cheap?</TD></TR></TABLE>
Koni and cheap do not go together. Expect to pay $450+ for a brand new set.
Old May 28, 2005 | 10:32 AM
.RJ's Avatar
.RJ
Default Re: Do Koni Yellows have any advantage over Illuminas besides ride height? (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chowmien &raquo;</TD></TR><TR><TD CLASS="quote">
Koni and cheap do not go together. Expect to pay $450+ for a brand new set.</TD></TR></TABLE>
A $450 set of shocks as good as koni isnt expensive......
kevinm1981
Suspension & Brakes
18
Jul 10, 2010 02:05 PM
allmotorlsbaby
Suspension & Brakes
Apr 10, 2009 09:03 AM
mingbling96
May 1, 2005 07:43 PM
OVRsi
17
Mar 9, 2003 12:19 PM
YodaIsGod
15
Jan 29, 2002 05:51 AM
