engine swap to a h22a dohc v-tech
Old May 26, 2005 | 07:07 PM
95accordman's Avatar
Default engine swap to a h22a dohc v-tech
i just wanted to kno if anyone know if it would be hard because it looks like everything is placed exactly the same as my stock motor which id a f22 b sohc non v tech and i wanted to know if it would match up to the same mounting points thanks
Old May 26, 2005 | 08:10 PM
kid-crx's Avatar
already have done the swap and yes it it all mounts up the only mount u have to change is the drivers side and for that just use the stock h22a drivers side mount otherwise it drops right in
Old May 27, 2005 | 07:27 AM
Monkey Fing a Coconut's Avatar
Default Re: (supportRhondas)
you also gotta plug it in to outlet, phone jack, and put the battery in and let it charge for 24 hours before use before v-tech will work...jp
anyways, with the jdm swap which you will most likely get, you gotta lengthen fuel line as it is on opposite side, convert to internal distributor, and the header will not line up to the stock exhaust so you gotta take it to a muffler shop, also knock sensor will need to be wired, maybe a few other things i missed or i said the opposite, search around, the answers are here...
DavidlXeon
Sep 10, 2013 04:36 PM
sloaccord97
Apr 12, 2010 06:46 AM
honda4life4456
Oct 28, 2003 05:44 PM
Tiger95
Oct 9, 2002 10:53 AM
mattmw88
Nov 1, 2001 09:08 AM
