Codes 22 and 41 what do you think this is?
Old May 26, 2005 | 04:58 PM
Bimmerman's Avatar
Default Codes 22 and 41 what do you think this is?
Do you think i need a new O2 all so for the vtec pressure valve what can I do about that? vtec seems to be working great.
Old May 26, 2005 | 05:00 PM
komat's Avatar
Default Re: Codes 22 and 41 what do you think this is? (Bimmerman)
22 VTEC pressure valve
41 Primary oxygen sensor heater
if this is a swap recheck your wiring
Old May 26, 2005 | 05:05 PM
Bimmerman's Avatar
Default Re: Codes 22 and 41 what do you think this is? (komat)
well I removed my turbo kit on now the light is on, the swap has been in the car for about 8 months and never a light.
Old May 26, 2005 | 05:07 PM
komat's Avatar
check the wires maybe one got damaged while removing the turbo
Old May 26, 2005 | 05:16 PM
Bimmerman's Avatar
my oil was about a quart low could this cause a problem?
Old May 26, 2005 | 05:41 PM
Bimmerman's Avatar
I checked the wires and they look all good, I noticed when I had my test pipe made and put on car the light seems to come on and my air/fuel gauge quit working, could they have messed something up when welding?
RippSpeed
May 5, 2007 07:11 PM
preppy79
Jun 19, 2006 11:45 PM
tdizz07
15
May 30, 2006 08:05 PM
MikieSwartz
Aug 29, 2003 07:56 PM
