jg303 ls cams
Old May 26, 2005 | 04:38 PM
91ls-v's Avatar
Default jg303 ls cams
i'm going to pick up some jg 303 cams for my ls and was wondering if i should put new pistons in first or juss slap it on...
oh yeah the cams are coming with a 96 ls head with crower valve springs and retainers
what kind powers would i expect from this set up?
Old May 26, 2005 | 06:07 PM
ALLMOTA92EG's Avatar
well the higher compression will make you get more potential of those cams.
Old May 26, 2005 | 08:19 PM
hybrid_vtec's Avatar
Default Re: (jdm92civichb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92civichb &raquo;</TD></TR><TR><TD CLASS="quote">well the higher compression will make you get more potential of those cams.</TD></TR></TABLE>
B16 pistons are cheap and esy to find!
Old May 26, 2005 | 08:57 PM
91ls-v's Avatar
what all is needed to put pr3 or p30 pistons in??
Old May 27, 2005 | 08:22 AM
Default Re: (91ls-v)
Take your rods out and take them to a machine shop to have them pressed on.(about $30-40) Then buy new rings and rod bearings. Reinstall
Old May 27, 2005 | 09:19 AM
dohcter g's Avatar
Default Re: (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
B16 pistons are cheap and esy to find!</TD></TR></TABLE>
Old May 27, 2005 | 11:27 AM
93vtec's Avatar
how much are the rings and bearings usually do i need oem honda or can ijuss use some napa ****
Old May 27, 2005 | 11:59 AM
dohcter g's Avatar
Default Re: (93vtec)
Honda OEM rings are $110. You can give Honda a series of numbers on the block vs. the crankshaft and come up with the bearing colors. Same with the rods. You will have two to three diff. size main and rod bearing combinations for each motor. In other words you can not just go buy bearings. Bearings are about $11 per half at Honda.
Rods have bore size in number on the fat part of the rod. Match that with the letter of the Crank for that cylinder. That number-letter combo will tell you the color rods bearings you need.
The Letters are on the bottom of the block (hard to see where the oil pan gasket would be) Write down those letters in the same order and match them with the five numbers on the crankshaft. That letter-number combo will tell you the color mains you need.
Old May 27, 2005 | 01:39 PM
Default Re: (dohcter g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">Honda OEM rings are $110. You can give Honda a series of numbers on the block vs. the crankshaft and come up with the bearing colors. Same with the rods. You will have two to three diff. size main and rod bearing combinations for each motor. In other words you can not just go buy bearings. Bearings are about $11 per half at Honda.
The Letters are on the bottom of the block (hard to see where the oil pan gasket would be) Write down those letters in the same order and match them with the five numbers on the crankshaft. That letter-number combo will tell you the color mains you need.</TD></TR></TABLE>
nxvictim
Apr 4, 2008 11:59 AM
dohc_profile
Nov 13, 2007 08:32 AM
dc4teg95
Jun 29, 2007 12:43 PM
DShowers
Dec 1, 2006 07:21 PM
hb4u2nv
Jun 17, 2004 10:28 PM
