help! is it worth it?
Old May 26, 2005 | 03:59 PM
cambopheonix56's Avatar
Default help! is it worth it?
ok here is my situation:
I have a 00 si with SRI, Headers/Exhaust, NGK Plugs, and I have cam gears comming. My question is, if I get some 330 fuel injectors, skunk2 intake manifold, and skunk2 throttle body, how much of a gain will I get? I dont plan on tunning, if I dont have to, becaue no one around here tunes. Is it worth it? If not, any suggestions? Thanks,
Cam
Old May 26, 2005 | 06:38 PM
Default Re: help! is it worth it? (cambopheonix56)
bump
Old May 26, 2005 | 07:16 PM
isumase's Avatar
id say itd be a minimal gain if it isnt tuned right. not only that but the injectors will only pump as much as the fuel pump will pump out and the rail and regulator so without upgrading that and having it tuned it prolly wont run that great. im in the same bind right now and getting everythign together b4 i put it all on so i dont run into any tuning problems and im sure someone on here can help you find a tuning shop around your area.
Old May 26, 2005 | 07:53 PM
Default Re: help! is it worth it? (isumase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isumase &raquo;</TD></TR><TR><TD CLASS="quote">id say itd be a minimal gain if it isnt tuned right. not only that but the injectors will only pump as much as the fuel pump will pump out and the rail and regulator so without upgrading that and having it tuned it prolly wont run that great. im in the same bind right now and getting everythign together b4 i put it all on so i dont run into any tuning problems and im sure someone on here can help you find a tuning shop around your area.</TD></TR></TABLE>
I live in Mason City, Iowa, and I assume the closet shop would be Minneapolis, MN, or Des Moines, IA?? If I got it tuned, whatwould I expect?
Old May 26, 2005 | 08:14 PM
BauleyCivic's Avatar
Risky Business
Uh, if you don't tune injectors that are 40% larger than your stock ones, your motor will be receiving 40% more fuel than its supposed to and you will cause serious damage to your engine.
people these days
Old May 26, 2005 | 08:20 PM
5poonhatch's Avatar
i say TURBO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 26, 2005 | 08:42 PM
isumase's Avatar
Default Re: help! is it worth it? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Uh, if you don't tune injectors that are 40% larger than your stock ones, your motor will be receiving 40% more fuel than its supposed to and you will cause serious damage to your engine.
people these days</TD></TR></TABLE>
better put then how i could say it good answer
Old May 26, 2005 | 08:52 PM
ok now that my question still hasn't been answerd.. I thought this was a forum that questions got answerd on, not made fun of. So, If anyone would be kind enough to answer it, that would be very much appreciated.
Old May 26, 2005 | 08:56 PM
Risky Business
Injectors - 0 HP
Skunk2 Manifold - 2 HP
Skunk2 TB - 2 HP
Happy?
Old May 26, 2005 | 08:58 PM
neutron91's Avatar
no reason to get all that if youre not going to tune... especially the injectors... plus if you dont tune you are just shortening the life of your motor... so if that sounds good to you then i guess its worth it
Old May 26, 2005 | 09:08 PM
Default Re: help! is it worth it? (neutron91)
ok so i need to tune. Does any1 no of a shop around mason city iowa? Any in minnesota, or iowa, or wisconsin or anywhre close?
Old May 26, 2005 | 10:25 PM
Status Sean's Avatar
get it tuned ! and help this man find a shop or someone that can help him !
Old May 27, 2005 | 05:42 AM
Default Re: help! is it worth it? (rw92civic)
bump
HondaH22a#1
Jul 3, 2007 10:47 AM
vbspec
Jun 12, 2007 03:12 AM
khcivic
Jun 29, 2003 07:58 AM
zigs
Jun 11, 2003 10:06 AM
cornholioEK
Feb 15, 2003 11:11 AM
