type-s pistons
Old May 26, 2005 | 03:47 PM
92 CIVIC HATCH VX's Avatar
Default type-s pistons
ok i got a h22a4 motor i've done some research and i'm doing the conversion.
From what i got you can stay with your stock rods if you have a A4.
what rings should i get for the pistons?
Old May 26, 2005 | 03:48 PM
gaydm.accord's Avatar
Default Re: type-s pistons (92 CIVIC HATCH VX)
oem rings should do fine.
and h22a4 rods use the floating wrist pins so its pretty much plug in and play.
Old May 26, 2005 | 03:54 PM
Default Re: type-s pistons (gaydm.accord)
great the less hassle the better.
Does anyone mind if i post under this since it's a h22
I'm not getting fast replies At the hybrid forum.
I got a chilton prelude repair manual??
it's a 96-00 and all i see is the f22b1 and b2?
will that work for the h22a4?
Old May 26, 2005 | 04:05 PM
what do you mean will it work?
some information might be the same but not all of it is accurate. but depending on the work you want to do... i would go find a prelude manual if you want to do more intense stuff. also check out preludeonline.com its a really good site for preludes.
Old May 26, 2005 | 04:17 PM
bad-monkey's Avatar
so, let's say you get a set of Oversized Type S slugs, how intensive is the boring work to get the block bored out to accept them? would it be easier to just get the right A/B combination (which isn't easy.) also, what's the final word on honing?
Old May 26, 2005 | 04:23 PM
Don Jefe's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">so, let's say you get a set of Oversized Type S slugs, how intensive is the boring work to get the block bored out to accept them? would it be easier to just get the right A/B combination (which isn't easy.) also, what's the final word on honing?</TD></TR></TABLE>
Boring and honing are two of the main reasons why i decided against going with any kind of after market slugs. Between pulling out the block and taking it somewhere, not to mention the cost of the pistons themselves, was all just too expensive for me.
Now i dont say this to discourage you, as im sure you know what installing a set of pistons in a used block requires, its all about the $$ here.
Old May 26, 2005 | 04:26 PM
to get the OS pistons to work you will need a shop that is reputable and carries the right cutting diamond/stone for the frm sleeves. if not say good bye to your sleeves.
i prefer to take the A/B route
in my case its BBBB
Old May 26, 2005 | 04:38 PM
Default Re: (gaydm.accord)
yeah i have 150psi in all cylinders so i was just going to go type-s and resleeve the engine this winter.
will in need to hone if the cylinder walls are fine?
whats the diffrence between the A and B type?
Old May 26, 2005 | 04:39 PM
Default Re: (92 CIVIC HATCH VX)
A and B have different cylinder bores. the OS is just bigger than the A and B
Old May 26, 2005 | 07:12 PM
the one i'm looking at i think is a B set piston. I got the impression that i will not have to bore.
but if igo forged i will, thats why i couldn't just go with forged pistions.
Old May 26, 2005 | 07:20 PM
Old May 26, 2005 | 07:25 PM
i got ahold of the guy with the pistons and the are type a?
so what is the diffrence from a to b is it smaller or what or is there no diffrence.
Old May 26, 2005 | 08:22 PM
if you go forged you cant bore you have to resleeve.
is the one guy your talking about that guy with a set on egay?
the difference is that a and b have two different bore sizes as said above. its somewhere in the archived you can look it up. if you want to know if you need a or b you can also look it up in archived.
but quickly if you stand in front of your car it is located behind the motor under the head driver side. you might have to wipe down the block to see it.
Old May 27, 2005 | 05:32 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX &raquo;</TD></TR><TR><TD CLASS="quote">i got ahold of the guy with the pistons and the are type a?
so what is the diffrence from a to b is it smaller or what or is there no diffrence.</TD></TR></TABLE>
You need to buy a Helms manual . . . .
PWRDbyHseries
Mar 5, 2007 07:16 PM
kiwak
Jul 8, 2004 09:20 PM
SHhh__VTEC
Jan 12, 2004 11:51 PM
MisterB
Dec 18, 2001 08:26 AM
