Reserve gas light???
Old May 26, 2005 | 03:44 PM
georgiajdm's Avatar
Default Reserve gas light???
Quick question? On a 5th gen prelude should the reserve gas indicator light (orange circle light )come on briefly when the car is started (as an indicator that it is working like all the other warning lights)...
Just noticed that mine doesn't come on so I don't know if it's suppose to or not.
Old May 26, 2005 | 05:35 PM
94Vtecluder's Avatar
Default Re: Reserve gas light??? (georgiajdm)
No it shouldn't come on. At least it doesn't come on in 4th gens when you start it. Only when I'm low on gas, which is like all the time. DAMN YOU GWB!!!
Old May 26, 2005 | 05:42 PM
Shakes's Avatar
space cadet
Default Re: Reserve gas light??? (94Vtecluder)
reserver gas light doesnt come on in myt 5th gen or my accord.
Old May 26, 2005 | 07:04 PM
georgiajdm's Avatar
cool thanks...
the past couple of week the gas needle was notches below the last tick and the light has NEVER come on..
Old May 26, 2005 | 07:20 PM
NonStopReaper's Avatar
shouldnt come on. and even its below the notch it probably come on shortly after. sometimes it doesnt come on for a while. either way i heard it not good for your engine to be driving on an almost empty gas tank.
Old May 26, 2005 | 08:07 PM
georgiajdm's Avatar
indubitably, known to induce fuel starvation during g-loading.
Old May 26, 2005 | 11:29 PM
4LugR's Avatar
Default Re: (georgiajdm)
man, that gas light must never come on then, cuz im always low, and ive never seen it come on in my 5th gen.. im still wondering.. do 5th gens even have a fuel light???
Old May 27, 2005 | 07:48 AM
Kronn 98SH's Avatar
Default Re: (AEMPrelude916)
i'm not sure which is worse, your fuel light not coming on, or mine coming on with 4 gallons left in the tank....either way, i'd just like at the tripometer if you're worried about your amount of gas you have left
Old May 27, 2005 | 07:58 AM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">No it shouldn't come on. At least it doesn't come on in 4th gens when you start it. Only when I'm low on gas, which is like all the time. DAMN YOU GWB!!!</TD></TR></TABLE>
it does in my fourth gen, and it works fine. But hopefully you know how to read a gas gauge so you wont run out even if it were broken
Old May 27, 2005 | 08:07 AM
AndyD's Avatar
Default Re: Reserve gas light??? (Matt5745767)
I have never seen my gas light come one either.
I am going to test it one time. I am going to keep a gas can in my trunk and run the car until it runs out of gas to see if it ever comes on.
Old May 27, 2005 | 08:14 AM
meltman1234's Avatar
Default Re: Reserve gas light??? (AndyD)
When the light comes on in a 5th gen, about how many gallons are left? I've heard 3-5.
Old May 27, 2005 | 08:17 AM
AndyD's Avatar
Default Re: Reserve gas light??? (meltman1234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meltman1234 &raquo;</TD></TR><TR><TD CLASS="quote">When the light comes on in a 5th gen, about how many gallons are left? I've heard 3-5.</TD></TR></TABLE>
I highly doubt that. I would imagine 1-2 gallons at the most.
Old May 27, 2005 | 08:20 AM
94vtecmn's Avatar
I think it is closer to 3 or 4. I've driven mine 75 miles before filling after the light came on, and I get about 24mpg......
Old May 27, 2005 | 08:34 AM
AndyD's Avatar
Default Re: Reserve gas light??? (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">I think it is closer to 3 or 4. I've driven mine 75 miles before filling after the light came on, and I get about 24mpg......</TD></TR></TABLE>
You could be right. I am going based on what they say the gas tank's capacity is compared to what I usually fill up with 1-2 bars left.
I thought they said our gas tanks are 15.9 gallons. I usually fill up the tank using a little over 13 gallons. Again, that's with 1-2 bars showing on the gas guage. I am not sure when the gas light comes on.
Old May 27, 2005 | 08:35 AM
bad-monkey's Avatar
my light comes on when i've used about 12.5 - 13.0 gallons from full. capacity with reserve is 15.4?
Old May 27, 2005 | 08:37 AM
Shakes's Avatar
space cadet
ill admit, im horrid about driving with or until the light comes on. i think the most i have ever put into the car is just over 13.5 gallons. with a 15.9 gallon tank that leaves quite a bit of room considering the light comes on at about 305 miles (apx. 13 gallons)
tengty
May 7, 2011 07:18 AM
AndyD
Nov 29, 2007 01:16 PM
phish4709
Mar 28, 2007 04:33 AM
Eran
24
Feb 28, 2007 07:04 PM
duckie83
Apr 30, 2002 04:03 PM
