question about bleeding clutch
Old May 26, 2005 | 03:22 PM
azian21485's Avatar
Default question about bleeding clutch
hey guys, just finished bleeding the brakes (flushed out system with new fluid)..now for clutch...few questions
in helms it says to keep one end of tube on bleeder valve, the other in brake fluid...is this necessary or can i just bleed it like i bleed the brakes (push down pedal, release valve, close valve, release pedal)? reason i'm asking is that it's a pita to work around the slave cylinder with so little space..let me know guys thanks
Old May 26, 2005 | 03:33 PM
B20TDC2's Avatar
Default Re: question about bleeding clutch (azian21485)
you can do it the same way as brakes thats the way i do it . when you release the pedal it will stick to the floor just pill it up by hand and pump it 5-7 times and then hold down open valve , you know the rest . good luck
Old May 26, 2005 | 06:32 PM
DeadVet's Avatar
Default Re: question about bleeding clutch (B20TDC2)
Either way.
Old May 27, 2005 | 07:54 AM
JimBlake's Avatar
Default Re: question about bleeding clutch (1TurboHatch)
For both brakes and clutch, if you don't use a hose it's more likely you'll get air back into the slave/caliper. It doesn't always happen, but that's the reason.
Loop a piece of string under the clutch pedal to pull it back up. Have your foot on the pedal when you pull, so the pedal doesn't snap up quickly. That seems to suck air thru the MC piston seal (sometimes).
dc2LS
Oct 16, 2010 04:56 PM
thaimonkey
Jul 12, 2005 12:39 PM
hakemjmba
Jun 24, 2003 09:36 AM
riceburnah
Jun 2, 2003 04:23 AM
