88 accord flywheel
Old May 26, 2005 | 02:05 PM
Avenge's Avatar
Default 88 accord flywheel
Ok I have an 88 accord lxi 2 door. It was making a clack clack sound like the starter was slipping out of the flywheel. I took the starter up to kragen they said it was fine. I Checked the teeth on the flywheel for any flat spots. I could'nt find any, so do you think the starter is bad but they couldnt tell because it did'nt have any pressure on it?
Thanks in advance
Old May 26, 2005 | 02:15 PM
deserthonda's Avatar
did you take starter out?? if so were the starter bolts tight??? is noise definatelly coming from starter area?? what i mean is with car running you can pin point noise at starter area??
Old May 26, 2005 | 02:24 PM
Avenge's Avatar
No this is the noise when trying to start the car. Its like the starter cant fully grab the flywheel. Then it just wont start the starter will just keep spinning. The bolts were tight when I removed the starter.
Old May 26, 2005 | 02:53 PM
Vanilla Sky's Avatar
it's possible that the gear reduction is bad, or the gear and the flywheel teeth are more worn than you first thought... over on 3geez.com, there is a guy selling brand new lightened flywheels for like $150 shipped... give that a shot if you end up needing a new flywheel
Old May 26, 2005 | 06:31 PM
i am willing to be that you have a non factory starter installed ,,,,sometimes even new starter non hondas that i have installed are screamers and whiners ,,if all the teeth on flywheel are ok put a factory starter in
Old May 26, 2005 | 09:11 PM
Avenge's Avatar
Ok im not very mechanically inclined, so how much work is it to get the flywheel replaced?
Old May 27, 2005 | 03:46 AM
Avenge's Avatar
Upping this thread...Please
Old May 27, 2005 | 07:15 AM
you have to remve tranny to get to flywheel ,,it might be a difficult job if you dont have proper equipment//////but i tought you said all the teeth in flywheel looked ok if so why do you want to replace flywheel????
if the teeth are ok and if noise is coming from starter area and if it is a non honda starter, replace the starter with a honda 1
Fowled
Apr 25, 2015 11:28 PM
TylerC161
Dec 29, 2007 11:21 PM
Andyb22g
Nov 22, 2004 03:30 PM
non-VTEC
Apr 29, 2002 10:43 PM
