B20 on my 95 EG Questions??
Ok so I'm about to buy a good b20 block for $100 comes with crank and oil pan. I want to put a gsr head on this block but what do you guys recommend?? Can I use the b20 crank with gsr rods and type r pistons?? also what oil pump should I use GSR,B20,B16?? What water pump GSR,B20,b16?? what dizzy?? wiring harness?? and What ecu??? or what rods and pistons would you recommend b16,b18,b20,b18c5,b16b?? Also what tranny B16 or B18?? Also my car is a cx hatchback with the d15b8 engine can I use my stock ecu by using a chip??and can I use my stock wiring harness by just rewiring?? All your suggestions would be greatly appreciated. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_hatchback »</TD></TR><TR><TD CLASS="quote">Ok so I'm about to buy a good b20 block for $100 comes with crank and oil pan. I want to put a gsr head on this block but what do you guys recommend?? Can I use the b20 crank with gsr rods and type r pistons?? also what oil pump should I use GSR,B20,B16?? What water pump GSR,B20,b16?? what dizzy?? wiring harness?? and What ecu??? or what rods and pistons would you recommend b16,b18,b20,b18c5,b16b?? Also what tranny B16 or B18?? Also my car is a cx hatchback with the d15b8 engine can I use my stock ecu by using a chip??and can I use my stock wiring harness by just rewiring?? All your suggestions would be greatly appreciated. Thanks</TD></TR></TABLE>
holy schnikes!
holy schnikes!
I feel nice today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_hatchback »</TD></TR><TR><TD CLASS="quote">Ok so I'm about to buy a good b20 block for $100 comes with crank and oil pan. I want to put a gsr head on this block but what do you guys recommend?? USE A B16 or P73 IT-R HEAD, THEY FLOW BETTER
Can I use the b20 crank with gsr rods and type r pistons?? YOU USE THE B20 RODS, BUT THE B20 BORE IS BIGGER THAN ALL OTHER B SERIES
also what oil pump should I use GSR,B20,B16?? GSR
What water pump GSR,B20,b16?? GSR
what dizzy?? GSR
wiring harness?? STOCK
and What ecu??? CHIPPED P28 (PM me i have one for sale)
or what rods and pistons would you recommend b16,b18,b20,b18c5,b16b?? CUSTOM RODS AND PISTONS
Also what tranny B16 or B18?? B16 LSD or IT-R
Also my car is a cx hatchback with the d15b8 engine can I use my stock ecu by using a chip?? ABSOLUTELY NOT
and can I use my stock wiring harness by just rewiring?? SHOULD BE ALL PLUG AND PLAY WITH OBD1 PARTS + SOME VTEC WIRING
what dizzy?? GSR
little2fast4u
Aug 2, 2008 06:46 PM
H23vtecEG
10
Jan 22, 2005 02:34 PM
