How Fucked is My Engine?
Old May 26, 2005 | 12:35 PM
madhatter07's Avatar
Default How Fucked is My Engine?
Hey guys,
Ok i was about to do the timing belt on the car so i removed the spark plugs and plugs in the #3 and #4 cylinders were covered in oil. I think this means that the rings arent sealing and oil is getting shot all over my plugs, I'm going to run out and grab a compression tester and check it out but what is the probable diagnosis?
Old May 26, 2005 | 01:29 PM
JimBlake's Avatar
Default Re: How Fucked is My Engine? (madhatter07)
How'd the oil get all over the socket? It might be as simple as the sparkplug tube seals in your valve cover.
Old May 26, 2005 | 01:37 PM
Default Re: How Fucked is My Engine? (JimBlake)
the oil just got there from the spark plugs, there wasnt any on there when i pulled the plug out, there was ALOT of oil on those bad boys
Old May 26, 2005 | 02:59 PM
Chiovnidca's Avatar
Replace the tube seals.
Old May 26, 2005 | 03:55 PM
PURPLETERROR aka BIGMATT's Avatar
Sparkplug tube seals , its not your rings
Old May 26, 2005 | 10:09 PM
Default Re: How Fucked is My Engine? (PURPLETERROR)
wow, thank you so much guys, i went into a panick when i saw that, thanks again guys for the help
Old May 27, 2005 | 04:27 AM
JimBlake's Avatar
Bad rings or valve seals would leak oil into the cumbustion chamber. Then the firing tip of the plug would get cruddy with oily gunk, since oil it there would get partly burned.
Yours look like oil was sitting in a puddle ABOVE the threads of the sparkplug. That's not inside the combustion chamber.
Old May 27, 2005 | 04:45 AM
ATS*Mark's Avatar
OG triple OG
your motors fucked dood....hella fucked.
Old May 27, 2005 | 08:20 AM
Default Re: How Fucked is My Engine? (Hella_JDM)
Yeah, the part that ignites isnt all that bad loking the car does burn oil though. So this wouldnt let any oil into my engine to be burnt?
Hella_Jdm, why do you say that?
Old May 27, 2005 | 08:25 AM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madhatter07 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the part that ignites isnt all that bad loking the car does burn oil though. So this wouldnt let any oil into my engine to be burnt?
Hella_Jdm, why do you say that?</TD></TR></TABLE>
Because he is phawkin' with you.
Yea, replace the seals, I had the same thing, replaced them and it's fine.
Old May 27, 2005 | 08:33 AM
ATS*Mark's Avatar
OG triple OG
Default Re: How Fucked is My Engine? (92b16vx)
ya im ****** wit ya
replace the valve cover seals youll be good to go.
Old May 27, 2005 | 11:50 AM
haha oh ok, got me a little worried there, I'm off to fix the beast lol
Old May 27, 2005 | 10:05 PM
ATS*Mark's Avatar
OG triple OG
let us know how it turns out!!!
Old May 27, 2005 | 10:40 PM
Exempt's Avatar
Yea, my g/fs Civic was having that problem... I actually just pulled off the seals slapped some oil on them, and reseatted them... Its been fine since... If someone took off the valve cover, they can slip out of their positions and when u put the cover back on u may not notice they arent seated correctly...
banks358
Dec 27, 2009 08:26 PM
keyknow
May 30, 2009 08:02 PM
93FastLs
12
Oct 10, 2004 08:44 PM
respectblades
Apr 2, 2003 06:26 PM
ahc'monracing
Oct 5, 2002 09:19 PM
