High rpm's...whats wrong?
2day kinda started noticing that when I pass 7000rpm it start to not pull very smoothy pass that number, it tends to kinda lag starting there...but aint h22 redline 8000rpm...what could it be?
The h22's power band starts to taper past 7k...so its natural for it not to pull as hard after that but if your reffering to smoothness then thats different
you can advance your dizzy a little bit to move your powerband to higher rpm's, but on stock timing, power starts to fall off around 6800 rpms. I wouldn't rev to 8 on a daily basis either.
