jl audio w7 13.5
I recently bought a new sub the 13.5 jl w7.
I was wondering which amp could run this. I dont have any more funds for the jl 1000/1 which other sub could run it?
i have the kicker kx800.2, but didnt want to run that... i think its not enough poewr... jw..
Modified by milton at 9:37 AM 5/26/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milton »</TD></TR><TR><TD CLASS="quote">I recently bought a new sub the 13.5 jl w7.
Modified by milton at 9:37 AM 5/26/2005</TD></TR></TABLE>You will need 1000 watts RMS at least. 1200 watts RMS would be better. It's better to be overpowered then underpowered.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">i think that sub runs @ 3 ohms also... so yeah. good luck finding an amplifier that runs that sucker. if you do though, it will kick ***.</TD></TR></TABLE>
There are plenty of amps out there that will run at least about 1000Wrms at 3 Ohms. He's just going to have to drop about a grand either way unfortunately (to get *clean* power at least)...
If you wanted a cheaper alternative to the 1000/1 you could save a couple hundred bucks by buying a Memphis 1500D. At 3 Ohm it'll lay down at least 1100Wrms and at most decent dealers it'll run you about $200-300 cheaper than a 1000/1. Sounds damn good too, and they definately have a better warranty policy than JL has had recently.
***Note: Although I mentioned warranty policy, I actually still own and run a 1500D which I have had since 2002; still works perfectly...***
SSBP DC2
Audio / Security / Video
Apr 18, 2003 12:22 AM
