What collector gasket to use with Kamikaze header
Old May 26, 2005 | 05:11 AM
Paluce's Avatar
Default What collector gasket to use with Kamikaze header
I installed a Kami header and the gasket between the primaries and the collector keeps blowing out on me. I tried dead soft Aluminium, and paper (grifite impregnated) both failed in a day. Now I'm trying a copper gasket. I heated up the header and re torqued it, so hopefully this seals. What is everyone else using? What comes with the header? I bought the header used. I did check to see if the flange was flat and they were, so I'm stumped right now.
Old May 26, 2005 | 09:58 AM
Paluce's Avatar
Default Re: What collector gasket to use with Kamikaze header (Paluce)
anyone?
Old May 26, 2005 | 02:03 PM
DRAGLS's Avatar
back in the days when I had that header I ended up welding the two halfs together
Old May 26, 2005 | 02:25 PM
CRVRX's Avatar
Default Re: What collector gasket to use with Kamikaze header (DRAGLS)
I made a post about this somewhere.
Here's some tips:
Get the 'Mr Gasket' copper 2.5" 3 bolt gasket and 3 Grade' 8' 3/8" x 1 3/4" bolts with spring washers , flat washers and nuts. ( Not soft Home Cheapo bolts)
Torque to 40 ft lbs then run the car for a couple of days ( heat up and cool down several times)
Then re-torque to 45ft lbs. I have done tons for these headers and never had a problem using this method.
Speedy5966
Nov 12, 2017 01:26 PM
Loveless
Jul 29, 2003 08:41 PM
92TEGsrSC
Jul 29, 2003 05:57 PM
cccccccc
Jun 19, 2003 11:03 PM
ScottEK
Aug 25, 2002 02:53 PM
