question about alpine type r subs
hey wassup .. i ve been wanting 2 12 inch alpine type r sub .. b4 i get it .. i was jus wondering how it compares to subs such as W6's , fosgates, etc. ... if i was to get 2 12 inch type r's ,what kind of amp would u recommend me to run and also what kind of box .. thanks !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">hey wassup .. i ve been wanting 2 12 inch alpine type r sub .. b4 i get it .. i was jus wondering how it compares to subs such as W6's , fosgates, etc. ... if i was to get 2 12 inch type r's ,what kind of amp would u recommend me to run and also what kind of box .. thanks !</TD></TR></TABLE> What model of the Alpine Type R are we talking about? There are 4 models SWR- 1221D, 1242D, 1241D, 1222D. There is also a SRB-122CR, a SWR-1241D preloaded into a compound reflex box, ["ported"]
94
94
i want either the swr-1242d or the swr-1222d ... it seems like both of them are the same subs with different ohm but i dont know much about it so i dont understand which one benefits which
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">i want either the swr-1242d or the swr-1222d ... it seems like both of them are the same subs with different ohm but i dont know much about it so i dont understand which one benefits which </TD></TR></TABLE> Are you getting one or more then one sub?
94
94
go here this will help you out if your confused with wiring, and what ohm subs and amp to get, hope this help.
http://www.rockfordfosgate.com...d.asp
as far as the Alpine Type R's they are a very clean hitting sub (sq) even in a ported box and they are half the price of the JL W6v2
2 type r in 4 ohm you have to get a 1000w amp that runs in 1 ohm
i would recomend this amp
http://www.onlinecarstereo.com...13120
you can find this amp cheaper on ebay and i think you should get a ported box
thanks for the website for the amp .. but i m trying to stick with alpine for the whole sytem .. because i already have the alpine unit with all the speakers .. any recommendations on the alpine amps ?.. thanks
well since alpine doesn't have a mono block amp that is 1 ohm stable, than that means you have to get dual 2 ohm subs which you can run in 2 ohms. so that being said you have to get this amp
http://www.onlinecarstereo.com...14926
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">Get two 4 ohm subs and the alpine 500 or 1000 watt amp.</TD></TR></TABLE>
umm yea don't listen to this guy just get the 2 type r 12's in the dual 2 ohm and get the mrd-m1005 and you will be running in a 2ohm load, 1000 watts, 500 to each, thats perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">i am getting two </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacK_Dc4 »</TD></TR><TR><TD CLASS="quote">i want either the swr-1242d or the swr-1222d ... it seems like both of them are the same subs with different ohm but i dont know much about it so i dont understand which one benefits which </TD></TR></TABLE> The only diff. is the impedance of the VCs, and as they are both 500watt, [1500watt peak] you will need an amp that makes 1000 watts, most "mono block" amps are stable down to 2 ohms, so I would use a "mono block", [the Alpine MRD-M1005 will work if you can afford US$600, Alpine MSLP] and get the SWR1222D, [2 ohm VCs] parallel the VCs for a 1ohm load then wire the speakers in series to give you a 2 ohm load for the amp.
Another good amp for them is the JL Audio 1000/1 1000 watts rms into 1.5 - 4 ohms, then it makes no diff. if you get the SWR1222D or the SWR1242D
Although I am an Alpine fan, for sub bass I think the JL is the better amp, if the subs are installed in a proper sealed box, proper volume, proper bracing, proper seal, [airtight] and the box gets mounted to the car properly, and the amp is installed and wired properly, with a [2 farad cap] the sub bass will be tight, accurate and very loud, [if you want it to be]
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR515 »</TD></TR><TR><TD CLASS="quote">
umm yea don't listen to this guy just get the 2 type r 12's in the dual 2 ohm and get the mrd-m1005 and you will be running in a 2ohm load, 1000 watts, 500 to each, thats perfect.</TD></TR></TABLE>
The 500 watt amp is plenty. That is what I have powering mine and I have the same subs. As for the 2 4 ohm subs, that is my bad, I was thinking they were SVC subs, so yes... Get 2 2ohm subs to run a 2 ohm load. If you can afford it get the mrd-m1001 or 1005, I got the mrd-m501 because I didn't have the extra cash for the 1000 watter.
so if you have the money get the mrd-m1005 and the 2 12's dual 2ohm subs but if not you can go with what civic_speed99 said.
i would go with what i said earilier, it will sound better. if you go sealed it will sound very clean, but if you go ported it will be a little louder but not as clean as sealed. so you choose which you would be more happy with.
and btw you can get the Alpine MRD-M1005 for about $347 on ebay, that was the cheapest price that i saw.
0utaSight
Northern California (Sales)
Mar 8, 2007 12:50 AM
sLo B18b
Audio / Security / Video
Mar 3, 2002 12:22 PM
SiClone
10
Jan 24, 2002 09:20 AM
