flywheel.....
Old May 25, 2005 | 09:56 PM
R_type's Avatar
Default flywheel.....
is the flywheel size different from the 90-91 to the 89 si........
i just recently bought a clutch and it was for a 90-91 civic/crx (i have an 89 si)everything fitted except for the pressure plate.... it just wouldnt bolt up to my flywheel because the bolt hole pattern is a bit different.... any help would be appreciated
Old May 25, 2005 | 10:02 PM
Mach69's Avatar
Default Re: flywheel..... (R_type)
'88-'89 had 200mm clutch and flywheel surface, while '90-'91 had 212 mm. That is for all the models, including si. However, it is possible that you are putting the pressure plate on the wrong way, I think there are 3 ways it looks like it can go on, but only 1 right way, try moving the pressure plate around. Its also possible you got a '90-'91 clutch and '88-'89 pressure plate.
Old May 25, 2005 | 10:31 PM
R_type's Avatar
is it possible that i just get the 90-91 flywheel or that wont work?????
Old May 26, 2005 | 08:12 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R_type &raquo;</TD></TR><TR><TD CLASS="quote">is it possible that i just get the 90-91 flywheel or that wont work?????</TD></TR></TABLE>
yes, just get 90-00 flywheel
Old May 26, 2005 | 08:31 PM
bagpipe goatee's Avatar
this isn't for you, but anyone else who searches. 88's have a different spline count on the tranny, and therefore need a different setup totally.
but 89's have the same spline count as newer, just a different size clutch, which is all dependent on the flywheel. the flywheel was the same from 90 all the way to 2000 like jlicrx said.
Old May 26, 2005 | 10:04 PM
R_type's Avatar
thank you all problems are solved...... man i love honda tech...hahaha....
Old May 26, 2005 | 10:25 PM
Kryogen's Avatar
Default Re: flywheel..... (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">'88-'89 had 200mm clutch and flywheel surface, while '90-'91 had 212 mm. That is for all the models, including si. However, it is possible that you are putting the pressure plate on the wrong way, I think there are 3 ways it looks like it can go on, but only 1 right way, try moving the pressure plate around. Its also possible you got a '90-'91 clutch and '88-'89 pressure plate.</TD></TR></TABLE>
88 Ed's have a 190mm flywheel
89 ed's have a 200mm
and 90-91 have a 212mm
Old May 26, 2005 | 10:34 PM
2kTeg's Avatar
your best bet would be to get a 90+ sohc flywheel the clutch is easier to find and its bigger. You can use a flywheel from any sohc 90 and up
dtme46
Mar 7, 2009 11:07 PM
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
omgwtfbbqcrx
Apr 15, 2006 12:50 PM
jdmCivic925
Jul 28, 2004 10:11 PM
luderone
Sep 13, 2003 02:01 PM
