poor mans type r-ive searched??
Old May 25, 2005 | 09:09 PM
KillaB18's Avatar
Default poor mans type r-ive searched??
ok ive read almost every post about the poor mans type r. I want to know what ecu can you use on a basic poor mans type r setup. Here is the setup
gsr block-stock pistons
b16 head stock
OEM head gasket
Skunk 2 intake manifold
will running a 00si ecu make it run good. im looking for it to just run good and not cause a big problem until i can get new pistons and obd1 ecu and get it chipped and tuned
Old May 25, 2005 | 11:17 PM
sol_1320's Avatar
Default Re: poor mans type r-ive searched?? (KillaB18)
Reprogrammed P28 will do the trick
Old May 26, 2005 | 01:52 PM
KillaB18's Avatar
cool, but would the 00 si ecu make it run good until i can get a reprogrammed p28?
Old May 26, 2005 | 02:04 PM
sol_1320's Avatar
Default Re: (KillaB18)
What year and model is the car and year of engine and harness
Old May 26, 2005 | 02:57 PM
KillaB18's Avatar
its a 97gsr block and a 00si head. the car is a 98 integra ls. but i will get the vtec engine harness with swap and the 00 si ecu with the swap
Old May 26, 2005 | 04:57 PM
sol_1320's Avatar
use gsr ecu 96-98 from what i was told that 00si ecu will not work..........as for the rest I think we need some more peeps on this subject U will need to make some splice's I am almost positive on that
Modified by sol_1320 at 11:24 PM 5/26/2005
Old May 31, 2005 | 02:59 PM
KillaB18's Avatar
splice's on what??
Old May 31, 2005 | 06:11 PM
skunkwhat's Avatar
yeah pretty sure the 00 ecu, wont plug into the 98 car harness.
p28's are cheap, so are conversion harness'
he might be talking about adding vtec wires to the ls car side harness(splices)
nuffsaidmikey
29
Mar 16, 2014 06:27 PM
Si-ONARA
Oct 7, 2008 07:57 PM
mcyang87
Dec 24, 2007 01:01 PM
CHAMPwhteEK
Dec 21, 2005 09:49 AM
infocrx
Feb 21, 2005 04:53 PM
