anyone knows of some sort of electronic device that cut boost after reaching a preset amount ?
Old Feb 6, 2002 | 08:53 PM
Flamenco-T's Avatar
Default anyone knows of some sort of electronic device that cut boost after reaching a preset amount ?
sorta like a prevention to boost spiking?
so let's say I set it at 9 psi if it ever spike that high, it'll automatically open the wategate to dump exhaust gas out ...
Old Feb 6, 2002 | 09:00 PM
VaporTrail's Avatar
New User
Default Re: anyone knows of some sort of electronic device that cut boost after reaching a preset amount ? (
Hondata
It has a boost cut circuit which will cut power if a certain boost pressure is exceeded. It is user definable.
[Modified by VaporTrail, 1:01 AM 2/7/2002]
Old Feb 6, 2002 | 09:02 PM
dustin's Avatar
I was just gonna say Hondata but it looks like John beat me to it
Old Feb 6, 2002 | 09:16 PM
Flamenco-T's Avatar
hmm, is this available on any stage with boost option ?
Old Feb 6, 2002 | 09:28 PM
austrian type-R's Avatar
I thought the Apexi AFC-R is also able to prevent boost spiking?
Old Feb 6, 2002 | 09:32 PM
dustin's Avatar
The AVC-R can control boost, but if the wastegate or some other issue is causing boost to spike it can't control it. Hondata just cuts fuel when it senses too much boost...
Dustin
Old Feb 6, 2002 | 09:35 PM
gtcali's Avatar
Dustin
That kinda sounds bad. Cutting fuel?
Old Feb 6, 2002 | 09:47 PM
dustin's Avatar
Injecting zero fuel doesn't hurt anything. You get no combustion.. that's what you want.
Dustin
Old Feb 6, 2002 | 10:25 PM
boomslang's Avatar
It's not electronic, but that's what a pop-off valve is for, to prevent boost spikes.
Old Feb 7, 2002 | 02:52 AM
JM Performance's Avatar
Yeah, I run one .......You need two things: a msd softtouch rev limiter (or 6 series ignition with this built in), and either a gauge w/ a warning light (and output at warning....like the Greddy gauge) or a pressure switch.
What you do is have the gauge or switch hit a relay that switches between the msd running through the rpm pill or running strait (no resistor).
This method has been working great for me. In addition I will soon be adding a NOS fuel pressure safety switch so I can't pressure drop out on me.
If you want more info on this and wiring schematicpoo poo me up.
Old Feb 7, 2002 | 03:12 AM
BlueShadow's Avatar
Dustin
does it also cut the spark too? I'm sorry If it sounds like a silly question, I'm just trying to understand how this stuff works.
Old Feb 7, 2002 | 05:20 AM
b18b98's Avatar
Hondata
Damn do I want Hondata..
Old Feb 7, 2002 | 07:51 AM
brian b's Avatar
New User
blitz dual sbc will reduce boost by x when your preset limit is reached..
Old Feb 7, 2002 | 07:57 AM
VTC_CiViC's Avatar
Hondata
One more reason I can't wait for another 2 weeks when I can get my Hondata 2b
Old Feb 7, 2002 | 08:03 AM
dustin's Avatar
Will not do you any good if, say, the pressure line to the side port on the wastegate is severed. The boost controller is going to do you absolutely no good...
Dustin
Old Feb 7, 2002 | 09:58 AM
LsTurbo91's Avatar
zdyne has one too! i just make that area super rich and no timing! instant boost cut lol
Old Feb 7, 2002 | 10:17 AM
SiR Kid's Avatar
New User
I just let mine spike away.. which it has only done once or twice when my wastegate was hooked up worng... It was moving REALLY fast at 15-18 PSI
Glad my motor's built!
Pythagoras
Jun 26, 2005 01:05 PM
BlackThorN
Dec 21, 2003 12:51 AM
Acura_I-RS
Mar 3, 2003 11:56 AM
The Poopsmith
Dec 14, 2002 01:35 PM
