A/C in B16 CRX
off what car? any car w/ b16 motor? Del Sol? Civic Si? It will fit w/ HAsport mounts? It's a tight squeeze in there.
And stock compressor will work? or need b16a one as well?
Yeah, I had it in my old 89 Si with a B16.
Buy the Hasport AC Bracket and use the stock D-Series AC Compressor and stock ac lines. Everything will bolt up like stock.
Its not that tight of a fit. Worked great for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">wanta talk about tight fight do it with a GSR
it can be done
Fitment would be no tighter with a GSR. Dimensionally, the only difference between the two motors is a slight height difference (8mm).
it can be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver88crxsi »</TD></TR><TR><TD CLASS="quote">Just roll the windows down thats all you need
Yeah, right! That's going to work REAL well when it gets up to 100!
</TD></TR></TABLE>Yeah, right! That's going to work REAL well when it gets up to 100!
Yeah use the hasport a/c bracket. I had a bit of a problem with mine cracking, but Hasport dealt with me every time.
Eventually I got mad and took out my a/c, but go with a/c you'll be glad you did.
Hmm one look at your location makes your post invalid.
AC is on my to do list.
</TD></TR></TABLE>Hmm one look at your location makes your post invalid.
i have a gsr in a ef with ac i had to use a 88 crx compressor with all the lines and i used the ac brakect from jdmshit.com and my ac works great my car is a 88 sedan
Yeah but id like to be anywhere hot i hate it. it rains way to much. I'm movin to az or ca in a year. But heat i like so i dont mind no a/c. Opinion may change in time though
camel22
Apr 19, 2006 06:48 PM
