Piston-Valve Clearance and Main Oil Clearance
I have two questions.
1. When you clay the head, what do you guys use to accurately measure the compressed clay?
2. I've notice some people install a known bearings size in the mains, found the clearance between that and the journal and just go from there to get the right bearing size.
I was taught that this formula determines correct bearing size to use,
housing bore diameter - oil clearance - shaft diameter = bearing thickness
I just wanted to get everyone's opinion on which one would be more accurate or if it would even make a difference.
To get a clearance for your bearings, mains and rods, you need to get the code off the crank, block and rods. Then you need to get a Helm's manual if you don't have this yet and look at the graphs for mains and rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aakeobo »</TD></TR><TR><TD CLASS="quote">I have a eagle crank and a dart block though.</TD></TR></TABLE>
You can use plastigage,but your better off actually measuring the clearance with micrometers and a bore gauge.Or you can torque the bearings up in the block and rods and bring them and the crank to a machine shop and have them measure the clearance.
Glenn
Glenn
srmofo
Jul 20, 2009 10:59 PM
jelatime
Apr 3, 2008 05:14 PM
