Dizzy probelm I think
Old May 25, 2005 | 07:55 PM
tc_gts's Avatar
Default Dizzy probelm I think
the tach started jumping around today sometimes...
considering i swaped to a sir cluster i thought maybe that was the problem....Nope..
Driving i noticed the car start to kinda lose power when the tach was jumping..
then all of a sudden car died on the highway and tach just went to 0...
thank god I have free towing lolz...
NO spark..
rotor is turning...
smell some smoke from distributor and... there white stuff all over inside of it... like the sparks been jumping...
Ive heard it could be the ignitor...
i have an 91 crx si distributor I can use the ignitor off that ive heard
Old May 25, 2005 | 08:01 PM
tc_gts's Avatar
bump
Old May 26, 2005 | 06:30 AM
mahatma's Avatar
Default Re: Dizzy probelm I think (tc_gts)
I'm 99% sure it's igniter.
And you can swap any OBD-0 igniter in for it (not sure about B-series however)
Change the igniter STAT......and update the thread when you figured it out for sure
Old May 26, 2005 | 09:32 AM
ant$missShift's Avatar
Default Re: Dizzy probelm I think (mahatma)
bump
Old May 26, 2005 | 09:40 AM
EP3_05's Avatar
Replace the ignitor. They are known to go on the 88-91 civic/crx.
Old May 26, 2005 | 07:20 PM
tc_gts's Avatar
Default Re: Dizzy probelm I think (91civic)
ok i replaced the ignitor wit my crx si dizzy ignitor and it was running fine... then i went for a long drive wit my dad to check it out and...
and the rpms jumped again
and it started jumping the tach that is... and seemed like the same problem all over....
Any ideas need and greatly appriciated
Old May 26, 2005 | 07:40 PM
tc_gts's Avatar
bumpity
Old May 27, 2005 | 03:14 AM
tc_gts's Avatar
bump
Old May 27, 2005 | 05:36 AM
mahatma's Avatar
Well we're pretty sure the problem is in the distributor, with it smoking and all. I assume it's tightened down well? Plug wires and connections all secure?
I've had a bearing seize in the distributor.....well not seize but stick really bad. It got so hot it melted the rotor and burnt the coil up. Maybe you're just suffering from a bad dizzy. At this point, if I were you, I'd pony up the cash for a new one if you can't wait to find a used one locally.
And look on the bright side........any money you spend troubleshooting is like free parts because some jackass "professional" would charge you more than that just in labor
Actually I guess the best advice would be to follow the service manual's diagnostic check of the ignition system, using an ohmmeter. Personally I hate doing that and I'd rather just buy the most likely culprit parts
Old May 27, 2005 | 06:09 AM
mahatma's Avatar
What car is this?
Old May 27, 2005 | 11:21 AM
tc_gts's Avatar
im a mechanic and so is my dad but i wont take offence to the comment lolz...
well ya i check the resistances and everything and there all pretty much within specs...
my ignitor wires were kinda loose... so i tighten then up.. changed the cap and rotor and ill let you guys know what happens to day lol k
Old May 27, 2005 | 03:31 PM
tc_gts's Avatar
ok i replaced the cap and rotor now and it seems to be fine but i failed emmissions on CO .. i passed the practice test with .42 out of an allowed .44 but then actual test failed with 1.60
Old May 27, 2005 | 03:40 PM
CRXSI_09's Avatar
I had the same problem with my crx. Switched out distributor and problem hasn't came back... knock on wood.
Old May 27, 2005 | 07:51 PM
tc_gts's Avatar
Default Re: Dizzy probelm I think (CRXSI_09)
well also the fact the thermostat ground was bad lolz that didnt help as well as loose wires to the ignitor
Old May 28, 2005 | 12:42 AM
silentblackhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tc_gts &raquo;</TD></TR><TR><TD CLASS="quote">well also the fact the thermostat ground was bad lolz that didnt help as well as loose wires to the ignitor
its fixed?
sharmon
32
Feb 24, 2011 02:19 PM
Canadian_EF
Mar 27, 2009 03:23 PM
lsvtecpwr
Jul 29, 2007 02:03 PM
MtnCRX
Jan 11, 2006 10:51 AM
B6teen
Nov 12, 2001 11:20 AM
