which offset/tiresize are you guys using?
Old May 25, 2005 | 05:37 PM
giff74's Avatar
Default which offset/tiresize are you guys using?
I am looking at the Rota C10's, 16x7, 5x114.3, which offset should I get? I am also looking at tires to go with them, thinking 205/50/16. This is with Eibach Sportlines and HP's on the car.
Appreciate any help with recommendations on which offset or tire size. Also wondering where the best prices are for the wheels.
Thanks
Old May 25, 2005 | 06:10 PM
SiR Phil's Avatar
Default Re: which offset/tiresize are you guys using? (giff74)
Offset for an EP3 should be between +40 and +45, optimally, though I think you can get away with +48.
Old May 25, 2005 | 07:05 PM
Lucid Moments's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giff74 &raquo;</TD></TR><TR><TD CLASS="quote">I am looking at the Rota C10's, 16x7, 5x114.3, which offset should I get? I am also looking at tires to go with them, thinking 205/50/16. This is with Eibach Sportlines and HP's on the car.
Thanks</TD></TR></TABLE>
With a 7 inch wide wheel you should be able to go wider than a 205. Have you considered a 225? 225/50/16 gets you within .09% of stock overall diameter, and I think it would fit. I know it would on a '02, but I'm assuming from the 5 lug pattern you have an '04+?
Old May 25, 2005 | 08:32 PM
chunky's Avatar
I have an 02. offset is +37.
down with high offset! sub 40 or die.
Old May 26, 2005 | 02:07 AM
giff74's Avatar
Default Re: (chunky)
I always forget which way this goes, is it the higher the offset the more the wheel is moving towards the car?
It looks like the c10's come in 40, 45, and 48 offsets, with the 205's or 225's and the Sportlines, which is going to make sure there is no rubbing?
Thanks
Old May 26, 2005 | 04:07 AM
kung fu grip's Avatar
15x7.5" +43 front, +38 rear. eibach sportlines.
225/50-15
yes, the higher the number, closer the wheel is to the center of the car.
Old May 26, 2005 | 06:05 AM
t o m's Avatar
Default Re: (kung fu grip)
im running 17x8 +35 offset
running 225 45 17 dunlop fm901's
Old May 26, 2005 | 10:57 AM
chunky's Avatar
Default Re: (integra type s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra type s &raquo;</TD></TR><TR><TD CLASS="quote">im running 17x8 +35 offset
running 225 45 17 dunlop fm901's</TD></TR></TABLE>
that's what I like to hear.
with 205 & 225's, you won't have any inner fender rubbing issues with a +40 offset or less. when you get into the +48 range, you risk rubbing on the inside.
+35-+40 is the optimum range IMO. It brings the tires right out to the edge of the fender and with a proper alignment you can ensure you won't rub on the outside fender.
see, you want it right out to the edge of the fender. Note the top of the wheel well and the fattest part of the tire. damn near perfect with -2.5 camber on 225/50/15's on a 15x7 +37 offset wheel.
I did have to trim the rear fender to run the camber setting I wanted though. I wanted -1 deg in the rear and it rubbed. with -1.5 or so I would have been okay as far as rubbing goes.
Old May 26, 2005 | 12:43 PM
t o m's Avatar
Old May 26, 2005 | 03:16 PM
giff74's Avatar
So with 205/50 or 225/50 I would be set with the 40 offset and the Sportlines?
Thanks
Old May 26, 2005 | 03:34 PM
t o m's Avatar
Default Re: (giff74)
i ran a 215 50 falken ziex on some 17x7.5" black racing rims. the fender is all eaten up. offset of those rims was +43 or +45
95BG33PGSR
Dec 10, 2005 07:45 PM
B16CRXT
May 25, 2005 03:12 PM
1Tym
Aug 24, 2004 03:39 PM
MRDC2
Feb 21, 2003 05:33 PM
vertius
Mar 14, 2002 08:20 AM
