High compression motor with what octane
Old May 25, 2005 | 04:47 PM
unknown0001's Avatar
Default High compression motor with what octane
Hey guys I have a quick question
I'm gathering up some knowledge to build up my LS/Vtec motor and have put in a good amount of information reading and researching.
I was calculating my estimated compression ratio for when my motor is done and it came up with 11.973719167158128 :1 compression so basically 12:1
My motor setup will be a b16a1 head with aftermarket valvetrain with a b18a1 LS bottom, stock LS rods with CTR B16b Pistons.
Would 12:1 compression be too high for running on 92 octane gas?
My friend suggested I go with PR3 B16 pistons and run around mid 11:1 compression.
I am wanting to build up a quick motor but also a reliable one.
I used the following compression calculator from C-speed Racing.
http://www.c-speedracing.com/h...c.php
Old May 25, 2005 | 10:06 PM
Default Re: High compression motor with what octane (Mr.RHTuner)
up
Old May 26, 2005 | 04:20 PM
up for high compression question
Old May 26, 2005 | 08:23 PM
six7one's Avatar
A little too high c/r for 92 octane. It all depends on the wieght of the car the tune and how u drive.
Old May 26, 2005 | 08:26 PM
ALLMOTA92EG's Avatar
you can get your car tuned to 92 on hondata but i think if you ran a higher octane you would get full power out of that motor.
Old May 27, 2005 | 10:03 AM
Default Re: (jdm92civichb)
Thanks for the responses.
I think I'm going to get P30(JDM B16a) pistons and run about 11.5:1 compression and use 91-92 or so octane.
Thanks
Old May 27, 2005 | 12:09 PM
dohcter g's Avatar
Default Re: (Mr.RHTuner)
I ran 93 with 12.4CR no problems......just tune it. Dont forget to enter 0.00" for piston-deck height.
Old May 27, 2005 | 12:12 PM
dohcter g's Avatar
Default Re: (dohcter g)
Try this one, I like it better!
http://www.zealautowerks.com/
Old May 27, 2005 | 12:13 PM
HondaIntegraR's Avatar
i don't think you'll be at 12.1 cr, when you calcuated did you take into consideration that the pct sits out of the hole?
Old May 27, 2005 | 01:33 PM
91sihatch's Avatar
Default Re: (HondaIntegraR)
Dude check the sticky at the top for compression. Your gonna be at high 12 - 13:1 compression with CTR's. I suggest the P30's if your gonna be running 92 and want it as a reliable less hassle Daily driver. They would put you at about 11.8:1.
Old May 27, 2005 | 03:37 PM
channy's Avatar
Default Re: (91sihatch)
12:1 seems like you are playing with fire. Make sure you get a good tune for the type of gas you are planning on running.
Old May 28, 2005 | 06:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g &raquo;</TD></TR><TR><TD CLASS="quote">Try this one, I like it better!
http://www.zealautowerks.com/</TD></TR></TABLE>
Thanks...great site
using the b16 PR3 pistons with the LS block, b16 head and LS rods it came out to 11.3:1
can somebody explain to me the piston the deck height...is it when the piston is TDC or BDC??? and how would you calculate it?
thanks
Old May 28, 2005 | 08:12 AM
it is the height of the top base of the piston to the height of the block... if the piston are flush w/ the block, then its zero
civic-r11
Sep 7, 2009 02:37 PM
JUN-DA6
17
Nov 10, 2005 03:33 PM
HondaEF
Sep 14, 2005 10:56 PM
Flexin5
Aug 31, 2004 02:58 AM
sushibug
Apr 3, 2002 05:04 PM
