ITR 5 lug conversiob
i was just wondering if it would be possible to swap the itr suspension into a crx. my buddy has an eg that we swapped the itr suspension into and it handles like a champ.
If this isn't possible, what would be a good alternate to improve my crx's handling.(minus rollcage, strut bar, etc.)
The bolt pattern of the hubs will not increase your car's handling in any way. I would suggest coil overs or different shocks/springs and a bigger rear sway bar depending on your use of the car.
yes it can be done my friend did the whole itr suspension swap on a 89 crx si and it worked just fine, i recommend you use some lowering springs thought, he did after the swap looked too high
i know the wheel lug pattern won't affect the handling, but what will affect the handling are the shocks, that is what I am most concerned with.
i have an 89 crx si and i want to put 99-up itr brakes/suspension (aka 5 lug conversion) into it. i know all the parts i need to get, except for the axles. what axles did you use for this swap?
thanks,
Colin
thanks,
Colin
philscivic101
Nov 15, 2005 02:38 PM
CivicHB_92
77
Sep 4, 2002 12:38 PM
