Black smoke when i rev my car :(
Old May 25, 2005 | 01:08 PM
90AcuraIntegra04's Avatar
Default Black smoke when i rev my car :(
Alright i have noticed my back bumper is caked in black smoke or something. I pulled my spark plugs and they are DRENCHED in oil. Could this be valve cover gasket, head gasket and/or rings? I hope not rings but if they are please tell me, thanks!
Old May 25, 2005 | 01:30 PM
PLAGUED_DB7's Avatar
Default Re: Black smoke when i rev my car :( (90AcuraIntegra04)
You more than likely are in need of a rebuild. Good Luck.
Try changing valve seals, all gaskets then you can run a leakdown test/ see if
it made a diffreence. If not then you will need to replace the rings. (More than likely.)
Old May 25, 2005 | 02:20 PM
Sam92Teg's Avatar
Default Re: Black smoke when i rev my car :( (PLAGUEDDB7)
Are the plugs covered at the wire end or the electrode end? If the wire end is covered in oil, then your plug tube seals under the valve cover are leaking oil. This will cause a short to your spark plugs (the path of least resistence) making the spark weak, thus not burning the charge. When trouble shooting, it is always best to start with the easy fix first, then move on to the more drastic.
Old May 25, 2005 | 02:25 PM
Default Re: Black smoke when i rev my car :( (Sam92Teg)
if the plug tube seals under the valve cover are leaking oil , would that cause me to burn oil out of my exhaust? It is leaking inside the head onto the spark plug wires. I pulled the wire and it was drenched in oil but i am not having problems with spark tho.
Old May 25, 2005 | 02:26 PM
wht92teg's Avatar
like sam92teg sayed, try the seals, as long as your at it, change your valve cover gasket... sometimes you can get it as a package deal.
also, i have been informed that black smoked is sometimes cause by a lean condition, where as the air fuel mixture is off
Old May 25, 2005 | 02:31 PM
Default Re: Black smoke when i rev my car :( (wht92teg)
i was told i was running rich/lean, how do i adjust that with our integras?
Modified by 90AcuraIntegra04 at 6:16 PM 5/25/2005
Old May 25, 2005 | 02:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AcuraIntegra04 &raquo;</TD></TR><TR><TD CLASS="quote">i was told i was running rich/lean, how do i adjust that with our integras?</TD></TR></TABLE>
What is the current setup/ Mileage?
Old May 25, 2005 | 06:50 PM
wht92teg's Avatar
i would think that you would need an adjustable fuel pressure regulator
http://www.aempower.com/product_fuel_app.asp
Old May 25, 2005 | 06:53 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wht92teg &raquo;</TD></TR><TR><TD CLASS="quote">i would think that you would need an adjustable fuel pressure regulator
http://www.aempower.com/product_fuel_app.asp</TD></TR></TABLE>
nope not needed to solve problem
Old May 25, 2005 | 07:24 PM
I fixed it, i replaced all the valve cover studs and gaskets. When i started the car blue smoke pooooored out, i drove around and it got less and less. I finally got it to i can floor the car and no smoke. Thanks for all your help guys
keyknow
May 30, 2009 08:02 PM
dismemberment
Feb 18, 2009 02:51 PM
LucienRahl
Aug 7, 2006 05:10 PM
civicxspower
Jun 5, 2005 12:19 AM
D16SohcVtec
Oct 15, 2004 01:45 PM
