what radiator to run with gsr turbo setup?
Old May 25, 2005 | 11:30 AM
boosted1993's Avatar
Default what radiator to run with gsr turbo setup?
I'm thinking of getting the fluidyne full length radiator for the integra, or do people run the smaller ones that fit on one side? Will this fit with a turbo manifold? Do i need to swap for some new slim fans? help before i order this300.00 radiator...
Old May 25, 2005 | 12:06 PM
s2kdre's Avatar
Default Re: what radiator to run with gsr turbo setup? (boosted1993)
the half size looks better and holds more fluid than the stock one so why not. and you have alot more room left.
Old May 25, 2005 | 12:31 PM
adseguy's Avatar
My question is why do you need a new radiator? Unless your stock one is broken or you will be doin extreme road racing, there is no need for a new radiator. If you need a smaller one I suggest an OEM Del Sol VTEC (Dual Core) radiator.
Old May 25, 2005 | 12:39 PM
Default Re: what radiator to run with gsr turbo setup? (adseguy)
mine came apart at the seem. Fluidyne makes a full radiator and a half size one. which would be best?
Old May 25, 2005 | 01:20 PM
adseguy's Avatar
Stay stock since your engine will not be cooled better. Get a full size if you can fit it without your turbo or manifold hitting it, that's why most people convert.
Old May 25, 2005 | 02:22 PM
B18Flip's Avatar
if you definately need a new rad, just get a 1/2 core. It should provide ample cooling plus give you more room for the turbo setup. You can even use an oem delsol dual core for like 70 bucks
Old May 26, 2005 | 05:24 AM
Default Re: what radiator to run with gsr turbo setup? (B18Flip)
I decided to get the oem radiator. Thanks for thre input. cheaper to.
Old May 26, 2005 | 05:35 AM
Finland's Avatar
Oem works fine.
Old Jun 2, 2005 | 05:41 AM
Default Re: (Boondock Saint)
oem running like a champ again
Old Jun 2, 2005 | 05:50 AM
adseguy's Avatar
Default Re: (boosted1993)
OEM choice may not bling, but it ALWAYS works
Tootsie7944
Feb 9, 2012 01:56 PM
f90w
Dec 12, 2008 09:14 PM
fro
Sep 12, 2004 09:17 AM
BoOsTiN Dc2
May 23, 2004 04:43 PM
