T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO
Old Feb 6, 2002 | 06:52 PM
JaeOne3345's Avatar
Default T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO
i notice through reading the archived post, a lot of people recommend those who have scrounged DSM t25 turbos to get the HKS manifold as if it would fit perfectly. I just wanted to point out this could be incorrect info. I work at a lube place and a guy came in with a t25 HKS manifold set up. he had to have an adapter plate made, because the DSM t25 inlet flange is not the same inlet flange the hks manifold is intended for.
whilst reading some sites i came along this site: http://thenew.gamesbbs.com/~turbosi/...ard/index.html which shows the same dilemma.
maybe this has been beaten on a thousand times, just trying to watch out for fellow sohc turbo peeps.
Old Feb 6, 2002 | 07:49 PM
Smashback's Avatar
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (JaeOne3345)
I was going to buy this manifold last year but overboots.com told me it's no longer in production. I was planning to use a TD05-14B though.
Old Feb 11, 2002 | 01:27 PM
Turbo Laser's Avatar
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (mplex2000)
DSM T25 doesnt fit on the HKS manifold. The Nissan Silvia's T25 will fit though, if you can find one.
Old Feb 11, 2002 | 04:59 PM
no2nsx's Avatar
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (ZCTURBO)
You can use a factory turbo from a 300zxtt
Old Feb 11, 2002 | 05:37 PM
AutoboTxEK's Avatar
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (no2nsx)
only the JDM T25s will bolt onto an HKS manifold.
Old Feb 11, 2002 | 07:26 PM
liam821's Avatar
25 Year Member
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (AutoboTxEK)
what about the mitsu 14b/16g turbo? Will it fit?
liam
Old Feb 18, 2002 | 03:42 PM
16g-95gsx's Avatar
Default Re: T25 DSM TURBO AND HKS MANIFOLD MISLEADING INFO (liam821)
I was going to say that there are different bolt patterned T-25's. I would think if the stock T-25 wouldnt fit than the 16g or 14b wouldnt either. But hell for the extra performance I would have a custom mount fashioned.
96ej8MR
Sep 3, 2007 06:43 PM
mamaboy
May 19, 2004 01:17 PM
94t3accord
Oct 26, 2003 09:13 PM
Eric E
Sep 23, 2003 04:50 AM
ill_take_one
Jan 29, 2003 12:50 PM
