si injectors?
Old May 25, 2005 | 09:33 AM
baked_beanz's Avatar
Default si injectors?
ok i have a 90 dx dpfi. were are the damn injectors located at on this thing?? oh and i have two injectors off a 87 crx si. could i put them on my dx?? and were are my dx injectors located?
Old May 25, 2005 | 09:56 AM
FalkenSiR's Avatar
Default Re: si injectors? (baked_beanz)
Injectors are located vertically in front of the down-draft manifold. It's 2 green plugs. They don't even look like injectors. Therefore, the injectors from the D15A3 CRX Si won't swap over.
Old May 25, 2005 | 10:19 AM
EP3_05's Avatar
As was mentioned the injectors are placed vertically in front of the downdraft manifold. And mpfi injectors will not work. Only the dpfi dx/std injectors will work.
Old May 25, 2005 | 11:43 AM
damn i was hoping it would work. what kind of injectors could i move up to without it bogging down
Old May 25, 2005 | 11:45 AM
EP3_05's Avatar
Default Re: (baked_beanz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baked_beanz &raquo;</TD></TR><TR><TD CLASS="quote">damn i was hoping it would work. what kind of injectors could i move up to without it bogging down</TD></TR></TABLE>
What mods do you have that you feel necessitate an increase in injector flow?
Old May 25, 2005 | 12:02 PM
intake,header,exhaust,advanced timing,2 1/2 inch piping straight back no cat or resinator,bosh platnuim 4's,removed restrictor plate(more airflow) and low temp thermostat. i just wanted to get some upgraded injectors
Old May 25, 2005 | 12:07 PM
Rywire's Avatar
You need a mpfi swap man. You dont need new dpfi injectors, trust me.
Old May 25, 2005 | 01:30 PM
mdarnell's Avatar
Default Re: (SloS13)
mpfi
Old May 25, 2005 | 01:56 PM
im kinda scared to do the wiring. the info on here is confusing
RACEPAK
Apr 29, 2010 01:42 AM
RACEPAK
Apr 29, 2010 01:41 AM
A13sechatch
Mid-Atlantic (Sales)
May 25, 2009 08:26 PM
driftam1
Apr 21, 2008 10:19 AM
MidoriEK4
Mar 2, 2003 02:53 PM
