MUGEN Chip or SPOON Chip?? which is better?
Old Feb 6, 2002 | 06:30 PM
905_S2K's Avatar
New User
Default MUGEN Chip or SPOON Chip?? which is better?
I know a shop that says they can burn me a copy of the Mugen ECU program or Spoon ECU for a good price, which is better, and what type of mods/setup do u need on your ride to benefit from each program?? Any of you ever used either of these ECU's either original or copied? What type of HP did you gain or can expect to gain? Thanks guys.
Old Feb 6, 2002 | 07:41 PM
mugenr#1011's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (Mugen-EG6)
what are your plans for the longrun?....if you decide to go with some new cams other than oem honda, you wont be able to run the program..
Old Feb 6, 2002 | 08:22 PM
t's Avatar
t
A lot of the copies are not what they say it is. You might or might not be getting Mugen or Spoon. If you are stuck between the two ask the shop if they are willing to let you try out both and you buy the one that performs better.
[Modified by t, 9:22 PM 2/6/2002]
Old Feb 6, 2002 | 08:27 PM
AJ PwR's Avatar
In order to make the Mugen or Spoon ECU work you will need the following :
-11.3 CR
-98-100 octane fuel
Old Feb 6, 2002 | 08:28 PM
Hondata's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (t)
Why do you not ask the shop how exactly much the ignition advance and fueling differs from stock. That would give you an idea if the shop knows what they are selling. Ask them if the chips disable any of the sensors (such as knock sensor, secondary runners, o2 sensors) or any error codes.
In addition to the above CR and fuel you will probably need individual throttle bodies, and Mugen cams if you go with a Mugen chip.
[Modified by Hondata, 9:30 PM 2/6/2002]
[Modified by Hondata, 11:39 PM 2/7/2002]
Old Feb 6, 2002 | 08:32 PM
Chris's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (AJ PwR)
A member here makes 188 WHP in their R with stock internals and CR (JDM header and a FPR) with the Mugen ECU.
It works fine...
Old Feb 6, 2002 | 09:00 PM
t's Avatar
t
Default Re: MUGEN Chip or SPOON Chip?? which is better? (Chris)
chris- I think he is inquiring about the OBD1 Mugen/Spoon copies. Not the OBD2 Mugen computer.
Old Feb 6, 2002 | 09:03 PM
Chris's Avatar
oh.
Old Feb 7, 2002 | 05:12 AM
905_S2K's Avatar
New User
Thanks for the info guys, i'll ask the shop for some more info on what you guys told me so far. But Yes i am running OBD 1, and require a OBD1 program. I am also running approx 11.6:1 CR and i am using OEM type-r cams and i only get 94 octane gas here in Toronto, and i'm not gonna buy octane boost for every tank of gas. I doubt i will change to jun 3's or spec b's. I'm just looking for 180 or more WHP with at least 125 or more TQ and i also need a higher fuel cutoff for my R cams. (Running OBD1 GS-R ECU right now) That's why i was considering the chip as well. Will tuning my V-AFC on a Motec help a lot as well? If it is a copy of the Mugen or Spoon program, should i consider? Thanks again guys.
[Modified by Mugen-EG6, 9:13 AM 2/7/2002]
Old Feb 7, 2002 | 08:27 AM
B2FiNiTY's Avatar
Only get 94...stupid 91 here in cali.. Sorry, I'm just a bit bitter.
Old Feb 7, 2002 | 04:49 PM
peebrain's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (B2FiNiTY)
Mugen/Spoon
JUN program
jmop
Old Feb 7, 2002 | 09:57 PM
t's Avatar
t
Default Re: MUGEN Chip or SPOON Chip?? which is better? (NatuRaldisasteR)
Do they have a JUN copy program for OBD1 now??
Old Feb 7, 2002 | 10:41 PM
Hondata's Avatar
You will get far far better results with a Hondata stage 2 + tuning - and it will probably cost you about the same after you sell your VAFC.
Old Feb 7, 2002 | 10:52 PM
EGtoR's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (Hondata)
Let say there is no Hondata dealer in my area, so I went out and buy the stage 2 from a dealer in other area and there is no people in my area that with the stage 4. Will I need to fine tune the stage 2 with a VAFC or whatever to get the most out of it, because the program I got in the stage 2 wouldn't be perfect for my set up.
Old Feb 8, 2002 | 04:01 AM
Mike M's Avatar
Founding Member
Default Re: MUGEN Chip or SPOON Chip?? which is better? (MajuniorsITRfu)
Mugen front bumper
Hytech headers & exhaust system
fully bulit Jun B-18c5 with B-20 head
Hondata ECU
with custom Turbo unit down pipe
mugen side skirts
greddy blow valve
Blitz turbo timer & boost controller
mugen tit.valve springs set
mugen ground up brake system
spoon ground up suspension
Recaro red seats
apexi tac.
mugen strut bar
potenza so3 pole postion
volk Rays broze Rims te37
uh interesting setup there
A JUN B18C5 But with a B20 head?
Hytech Header and Turbo kit?
Old Feb 8, 2002 | 04:44 AM
DutchITR1689's Avatar
Default Re: MUGEN Chip or SPOON Chip?? which is better? (TypeRmsm)
Mugen front bumper
Hondata ECU
mugen side skirts
greddy blow valve
Recaro red seats
apexi tac.
mugen strut bar
Actually he got more than one Hytech header.
B20 head!!! Hahahaha
A blow valve!!! Hahahaha
Ground up suspension? Is the car lowered or raised then?
Mugen front bumper on a USDM nose?
so3 or S-03?
Broze rims?
Old Feb 8, 2002 | 05:05 AM
905_S2K's Avatar
New User
I don't think i can get a Hondata program anywhere near here. I can get JUN parts, but what setup is needed with the JUN program to make good use of it? IS there a diff between the MUGEN/SPOON OBD 1 and OBD 2 programs? OR i can just drive over to Yoshio's shop which is like 15mins from my house.
Old Feb 8, 2002 | 06:30 AM
MugenEg6's Avatar
Mugen doesn't offer cams to the general public. They are for race teams only.
Old Feb 8, 2002 | 06:32 AM
Default Re: MUGEN Chip or SPOON Chip?? which is better? (MugenEg6)
Are you two related? Mugeneg6 and Mugen-EG6?
Old Feb 8, 2002 | 08:14 AM
905_S2K's Avatar
New User
Default Re: MUGEN Chip or SPOON Chip?? which is better? (EuroITR1689)
Haha, don't think so, but nice name though!
Old Feb 8, 2002 | 08:27 AM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
go hondata or dfi. Much more versatile and worthwhile for the longrun
Old Feb 8, 2002 | 11:18 AM
mugenracer's Avatar
mugen do offer cams to the general public, at least they do here in europe, i have a set in my JDM integra Si, got them from the UK, no problem, Mardigras motorsport in the UK sell every mugen product available.
http://www.mardigras.co.uk/
tegda
May 5, 2007 03:05 PM
SiR Inspired ED7
Jun 13, 2004 11:19 AM
electron-eg
Nov 10, 2003 05:32 PM
Euro98ITR
Nov 28, 2002 06:03 PM
junglistgsr
Feb 26, 2002 07:51 PM
