auto trans wont shift out of park
hey my accord will not let me press the buttonm to shift out of park when i step on the brake. is there a switch that need to be replaced? any help would be appreciated.
my '95 had this problem for a day until it disappeared.
apparently the shift lock actuator is is not allowing shifting when the brake petal is depressed.
i inserted a key into the designated slot near the shift **** and released it. car could then be shifted and started in neutral as best as i recall-it's been awhile.
Simpler test. Push in on the brake pedal and listen for a clicking sound coming from the center console. If there is no clicking sound the the shift inter-lock switch is bad and needs replaced.
not true turbowa you could have a bad fuse for the shift lock solenoid and you would not hear any noise 99.9 % it has been brake switch system,, fuse or switch itself
W95civicEXcoupe
Sep 29, 2014 06:17 AM
vitalove00
Acura TL, RL & ZDX
Sep 30, 2008 05:57 PM
