smog Gurus: your help is needed
Old May 24, 2005 | 10:25 PM
teggytegteg's Avatar
Default smog Gurus: your help is needed
original post:
https://honda-tech.com/zerothread?id=1256131
my smog is in two weeks and my motor is burnin hella oil due to valve seals...
my homie just did an old fashion smog test today(without NOx) and the results are bad.
HC: 269
02: 1.2...
those are tremendously high and my boy said that i was runnin rich....and those results dont include Nox levels...
i havent tried using GTP but on thursday, i will check for any vac leaks and then use GTP and another smog test
so please smog gurus, i need your help!!!!!
thank you
Old May 25, 2005 | 12:42 AM
Default Re: smog Gurus: your help is needed (teggytegteg)
1:42 AM bump
Old May 25, 2005 | 11:12 AM
12:41 PM bump
Old May 25, 2005 | 04:36 PM
come on guys..i know someone out there can help
Old May 29, 2005 | 11:38 PM
ok my last bump...hopefully someone out there can help me out
Old May 30, 2005 | 02:43 PM
H_doubledeuce_A1's Avatar
Check your o2 sensor and cat. That GTP **** won't work on our cars, it will only make things worse. When was the last time you changed your cat and o2 sensor?? It also helps to warm up the cat to operating temperature before you go to the smog place. Hope this helps.
Nick
Old May 30, 2005 | 04:40 PM
93hatchin's Avatar
man if you are burning oil thats where the hcs are coming from.
My_EFsedan
Nov 18, 2009 06:54 AM
Nicks95GSR
May 21, 2008 07:37 AM
ca177or4
Feb 20, 2007 08:15 AM
HmgLauj69
Jul 8, 2004 10:59 PM
hndarcrb18c1
May 4, 2003 08:59 PM
