Suspension & Brakes Theory, alignment, spring rates....
H&R Sport springs and what shocks ?
Old May 24, 2005 | 09:28 PM
mhng's Avatar
Default H&R Sport springs and what shocks ?
im thinking of dropping my car with the H&R Sport springs (1.75/1.5 front/rear)
now the question is, what shocks should i get ?
i was thinking koni ?
did a little research and found that koni yellows will make it even lower than 1.75/1.5 ?? if so, by how much ? also, at what dampening setting should the yellows be on to be able to correctly handle the springs without damaging the shocks ?
what about the koni reds ? i don't know too much about those, so edumacate me
how bout the agx's ? will those make the car even lower ? dunno much about those neither
i want to keep it right around 1.75/1.5, don't want to go TOO low ya know
also, any camber kit needed ? or would a toe alignment will do for the front ? what about the back ? i'v heard of adding washers ?
Old May 24, 2005 | 09:45 PM
akteamster's Avatar
Default Re: H&R Sport springs and what shocks ? (mhng)
tokico blues or illuminas r good shocks tooo. with lifetime warranty! that or go with a full coilover suspension kit from tien or omni power
Old May 24, 2005 | 10:46 PM
mhng's Avatar
Default Re: H&R Sport springs and what shocks ? (akteamster)
i was also thinking about the Tein SS, but thats a lot of $$$ ... so i'm trying to save as much money as possible without getting crappy stuff
Old May 25, 2005 | 07:45 PM
akteamster's Avatar
TOKICO IS DEF NOT CRAPPY...REAL GOOD QUALITY FOR A GOOD PRICE
Old May 25, 2005 | 08:22 PM
blacksheep's Avatar
H&R sports are <U>way</U> to soft!!!
Old May 27, 2005 | 06:58 AM
ALLSPRINGS.COM's Avatar
Also an excellent match for the H&R Sports are Bilsteins they are availavle in Heavy Dutys witch work in specific applications w/ H&R Sports and for the ones that dont Bilstein Sports are the way to go. No adjustments just awesome handling and durabilty.
Old May 27, 2005 | 01:18 PM
kkim's Avatar
Default Re: H&R Sport springs and what shocks ? (blacksheep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">H&R sports are <U>way</U> to soft!!!</TD></TR></TABLE>
Doesn't look that soft to me...
For 96-00 Civics (EJ6-8 and EM1 chassis codes)
96-00 EX - 165F/80R (P/P)
99-00 Si (EM1) - 201F/99.8R (P/P)
97, 00-01 ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
CTR - 240/240 (L/P)
H&R OE - 280F/190R (P/P)
Eibach ProKit - 290F/190R (P/P
H&R Sport - 330F/280R (P/P)
Eibach Sportline - 310F/275R (P/P)
Gold-line GL 2.5" drop - 320/190 (P/P)
Gold-line GPS 1.25" drop - 275/160 (P/P)
Koni RSK Suspension kit - 154-205/270 (P/L)
Neuspeed SofSports - 260F/150R (P/P)
Neuspeed Sport - 280F/180R (P/P)
Neuspeed Race - 485F/395R
Skunk Coilovers -old - 400F/300R (L/L) for civic, 500F/400R for integra
Skunk2 Coilovers - new - 500F/400r (L/L)
Spoon Full Coilovers - 300/240
Progress Coilovers - 350F/250R (P/P)
Progress Lowering Springs - 320F/200R (P/P)
Ground Control Coilover - 380F/280R (P/P) (this is the standard kit and the springs are mildly progressive).
Tein RA/RE/RS - 783F/559R (L/L)
Tein HT - 1119F/448R (L/L)
Tein HG - 365F/129-196R (L/P)
Tein SS - 448F/224R
Tein Flex - 504F/280R
Tein S. Tech - 235F/140R
Tokico Illumina Kit - 250/123 (P/P)
APEX'i WS - 447f/178r
Suspension Techniques - needed
SSR Cup - 392/280
SSR S1 - 448/448
JIC FLT-A2s - USDM - 504F/336R (L/L)
Sparco - needed
For 02+ Civic Si (EP3): ~ Very special thanks to Mike (EXavier) for these!!!
Progress - 280F/500R
Eibach Pro-Kit- 15-20% stiffer then stock
Eibach Sportlines - 20-25% stiffer then stock
Sprint - 20-25% more then stock
H&R Sport - 25-30% more then stock
Tein SS - 336F/448R
Tein Flex - 448F/559R
Tein S. Tech - 157F/291R
Old May 29, 2005 | 06:53 AM
Type_RS_59's Avatar
Default Re: H&R Sport springs and what shocks ? (kkim)
I've been running H&R Sports and Tokico Illuminas on my '98 Integra RS since 1999. I've won several local championships in the STS class. I also run the stock front sway bar with a Comptech rear. 3 national champions have driven my car and told me not to change a thing because it's perfect as is. Very neutral with trailing throttle oversteer available when you want it. When it was weighed at the 2001 NE Divisional, the scale operator asked me where I had it corner weighted becauase they did a good job. He was shocked when I told him they were just lowering springs, not coil overs, and that the car had never been corner weighted. I always wanted coil overs but i'm so happy with this setup that I don't want to mess with success.
Old May 29, 2005 | 08:58 AM
_Cyclone_'s Avatar
My H&R sports are noisy because I'm using stock shocks. I'm thinking if I throw some good performance shocks in there it will solve that problem, but I'm not 100%. I know it's a good idea anyway... just don't use the stock shocks.
Old May 29, 2005 | 06:07 PM
Type_RS_59's Avatar
Default Re: H&R Sport springs and what shocks ? (CycloneBlue_1.6EL)
Stock shocks won't last very long when subjected to lowering springs because they are not designed to work in that range of travel all the time. I'm doing it on my daily driven Civic right now but that's only because I got everything for free. The stock shocks from my Integra and hand-me-down Tokico springs. The ride is great and there is no noise but I wonder how long the shocks will last. Anything beats the combo of AroSpeed coilovers on blown AutoZone shocks that were in it when I got it!
felixjr18
Suspension & Brakes
22
Apr 24, 2009 01:23 PM
661rex89si
Suspension & Brakes
Jul 14, 2006 03:23 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
2fast
Feb 12, 2002 09:32 PM
kendo
Aug 24, 2001 01:47 PM
