b16 slow leak
Old May 24, 2005 | 09:15 PM
tpod's Avatar
Default b16 slow leak
hello i searched a bit and still not sure. it is hard to tell exactly where the leak is coming from. i think it might be the thermostat gasket or the o ring, but not sure. the coolant leaks slowly collects around the vss and then drips down the side of the tranny and the shift linkage. i guess my question is can this be anything else besides what i mentioned, im going to try to replace the gasket and see how it does from there. thanks in advance
Old May 24, 2005 | 09:30 PM
eda6's Avatar
Default Re: b16 slow leak (tpod)
Are you using factory hose clamps or the ones that you must tighten?
I've noticed that the clamps that you tighten seem to loosen every few months.
Get an inspection mirror and pinpoint your leak.
Old May 24, 2005 | 09:36 PM
tpod's Avatar
i will try to use one tommarow in the school shop, mostly using the factory clamps, but the biggest hose uses the tighting one.
Old May 24, 2005 | 09:51 PM
eda6's Avatar
Default Re: (tpod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpod &raquo;</TD></TR><TR><TD CLASS="quote">the biggest hose uses the tighting one. </TD></TR></TABLE>
Mine comes loose and leaks every three or four months. I think the problem will go away if oem hose clamps are used.
CptHMCrunch
Sep 13, 2013 06:29 PM
igo4bmx
17
Oct 11, 2006 07:32 AM
ahasan
Feb 16, 2006 07:40 AM
nahmanitscool
Apr 11, 2005 11:23 AM
steve_s
May 3, 2003 11:30 PM
