MSD cap fitment problems with a twist...confused...help please!
Old May 24, 2005 | 07:35 PM
xxxmikenicexxx's Avatar
Default MSD cap fitment problems with a twist...confused...help please!
So here is the problem...I just bought a built b18c to do a swap into my DA. I had originally bought an MSD cap and coil for the b18a that was in it, so since I had the coil i decided to get one for the b18c. So the cap comes, and one of the bolt holes (left one) would not line up whatsoever. Thinking the part was defective, I sent it back to Summit only to be sent a cap with the same exact thing going on. Out of curiosity, I decided to try the cap from my b18a on it, and it fit perfectly! Now what the hell does this mean, is it an ls distributor? If so, will that cause problems, as in should a b18c distributor be used? All insight would be greatly appreciated. TIA
Old May 25, 2005 | 05:50 PM
Default Re: MSD cap fitment problems with a twist...confused...help please! (xxxmikenicexxx)
Bump
Old May 25, 2005 | 07:56 PM
black6gen's Avatar
Are you sure the dizzy that came with the motor is the right one? As far as using a Ls dizzy on the gsr i dont think that is going to work. If all else fails just buy a dizzy and cap for the b18c.
Old May 26, 2005 | 03:13 AM
Thtas the thing, Im not sure if it is, from what i understand though as long as distributors are the same OBD they will work. And since Im not sure of it I need someones insight. Thanks.
BreakMaster
Sep 9, 2004 11:49 PM
drumking15
May 5, 2004 12:04 AM
J2turbo21
Aug 21, 2003 07:43 PM
J2turbo21
Aug 21, 2003 04:44 PM
dwn-shift
Feb 13, 2003 07:35 PM
