need to know how to reset my computer and fix computer cel coeds
i have a b16a1 pr3 motor and need to check for codes. if i get a code for say, the tps sensor has gone bad and i replace it how do i get rid of the code without a scan tool or can i use a obd1 scan tool. its an obd0 as youll know. also if i fix it how do i reset the computer i puller the fuse for the ecu and took the battery off numerous times but it runs the same. i herd you are supposed to pull the hazard fuse, is that correct? if its a automatic motor on a j1 trans what do i replace to make this thing run liek a honda beast? do i need to replace the cams and valves, spring retainter ect?
does anyone know what the vacuum lines should be hooked up to? its a motor out of a xsi and maybe its jsut i need a different map sensor or something. i jsut t'd the hoses to gether and fed them to the stock MAP SENSOR.
I ALSO HAVE THE STOCK FUEL PUMP FOR A CRX DX DO I NEED TO CHANGE IT IS THAT Y I CANT GET THE CAR TO GO OVER LIKE 7 GRAND?
THANKS GUYS FOR HELPIN OUT ANOTHER HONDA NUT LOL!!!
If a sensor is defective, it's defective. Let it go. Might look into replacing. ECU reseting can only do so much and for so long for you.
its almost like a warning
