Pics and Info bouts a teg I might buy tomorrow...
Old May 24, 2005 | 06:33 PM
KMD's Avatar
KMD
Default Pics and Info bouts a teg I might buy tomorrow...
Alright, I went and looked at a gsr (96 with almost 89k) today after work. I wasn't really sure what to expect, but I was pretty suprised about the quality of the car.
We'll start with my inspection...
Car looks great on the outside. I checked to make sure body panels lined up, shecked for signs of a damaged frame and repair. The carfax states the car has been in two accidents. They are not in the severe listing, but they are noted. I found a hole drilled behind the drivers side door in the door jam where... an entrance point o obviously pop a dent of some kind. That is the only sign of any repair done to the car.
It has one door ding about the size of a dime. Paint is great. It looked to me like this car had a winter undercoating. In the glovebox I found that it was bought in New York, so I wouldn't be suprised if it did have a dealer installed undercoating. The wheel wells are rust free. The bottom of the car is extremely clean. The engine bay showed no signs of leaks of any kind. It was clean, but not overly clean like they tried real hard to cover something up. Everything looks straight otherwise and lines up well.
I then started the car and continued to inspect the inside and out while letting it idle for about 15-20 mnutes. It idles fine, and the temp guage never went over 1/4 high. The inside is also very clean. The beige leather has very early signs of wear in the right area. No big deal though.
In the glove box I found the original manual and the name of the original purchaser, a women. As I said before, it was purchased in NY and is now here in VA. Carfax reports 3 owners.
I checked to make sure the VIN numbers matched in all 5 or 6 places I saw them, including the one on the firewall. The title is clean.
So, then it is time for the test drive. They let me take it out on my own, which gives me a chance to stop again and check things out. Again, nothing to note. It turns well, no clicks. The only wierd noise is a bit of clutch chatter when I engage the clutch (while parked in neutral). It shifts smooth and there is no clutch slippage. I hit vtec for the first time in 2nd gear and it moves.. and sounds healthy. It drives straight and there are no vibrations.
Now, this car has been slightly modded. The intake is a true cold air intake. It goes to the front of the pass side wheel well. It seems to have a cat-back exhaust, and I really tried to remember the name of the muffler.. but alas.. I forgot in all the excitment. It started with a B... not Borla.. but boessi.. I dunno.... anyway. I also found what looks to be a aftermarket rear sway bar and if obviously had a front strut bar. I don't know if the springs are stock.. Take a look at the pictures and tell me if it looks lowered.
Those are the only mods I found.
car seems very solid.. and there are no shakes or rattle. The only thing I regret is that i didn't take my digi-cam. All I can provide is the pics they had... and here they are:
It looks this good in person too.
Now, they are asking blue book value.. about $7700. I am ok with it though, if this car is everything it seems to be on first (but extensive) look. I am taking a friend with me tomorrow, with check in hand. He is gonna take a look as well to make sure I am not suffering from "Buyers Blindness".. and if approval is there, I will be driving it home tomorrow night.
So, what do you guys think?
Kirk
Old May 24, 2005 | 06:39 PM
94gsr_vtc's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (KMD)
well since you forgot to include the mileage, if its over 100k i wouldnt get it. this is just my opinion, but that green is ugly as **** with the tan interior. ive seen nice tegs in that color but i dont know. maybe get it to be different. what are your plans for the car? also depends what you feel is right and how long you looked for. i looked for around 4 months before i found the gsr i wanted. good luck and try to work down the price
Old May 24, 2005 | 06:40 PM
KMD's Avatar
KMD
Default Re: Pics and Info bouts a teg I might buy tomorrow... (94gsr_vtc)
Sorry.. 88k
The Green and beige is different, but I like it. I wouldn't do it just to be different. My plans for the car is to keep it as is for now (except get rid of that hideous muffler). It will be a DD. We will see what sort of an obcession this car will stir within me. I know the 87 crx si did it to me.
Old May 24, 2005 | 06:46 PM
xdc2b18c1x's Avatar
that car looks good to me. minus the rims though
Old May 24, 2005 | 06:48 PM
KMD's Avatar
KMD
Default Re: Pics and Info bouts a teg I might buy tomorrow... (xdc2b18c1x)
I got some Silver Rota Slips with Falken Ziex tires that will be goin on.
Pleasonton huh? I grew up in the Concord/Danville areas.
Old May 24, 2005 | 07:41 PM
Racermech's Avatar
How are the brakes???? It looks likt the E-Brake handle is pulled really high. From what i remember it is only supposed to go up 3-4 clicks. This could be a sign of worn out pads.
Body looks real clean, but the muffler looks like it is off center. Is that just the picture or just a crappy exhaust??? My teg had about 70,000 when i got it and now has about 94,000 and it runs like a champ.
If you are really serious I would get a compression test to make sure the engine has not been abused, pull the dip stick to see if the oil looks like it has been changed in the recent past.
Apart from that looks good!!!
Old May 24, 2005 | 08:05 PM
KMD's Avatar
KMD
Default Re: Pics and Info bouts a teg I might buy tomorrow... (Racermech)
Brakes seem fine, but again.. I'm coming from an 87 crx si, so anything is better than those brakes. I'll have em checked out.
BTW, it's a crappy exhaust. First thing I'm doing.. alarm.. second thing.. ditching that muffler.
Old May 24, 2005 | 08:12 PM
Racermech's Avatar
Carfax said it is a 1996 also?? It looks like a dark green, darker than my 96LS, maybe just the camera.
I know there was a different green to the 96 green. I was very close but a little darker
Old May 24, 2005 | 08:24 PM
KMD's Avatar
KMD
It's just the cam.. it looks more like a teal to me in person.
Old May 24, 2005 | 11:34 PM
DirtyzGsR_9i6's Avatar
i think you look over it close on the body again...is the emblems on the back of the car bondaled?...its a sign of probably some body kit being done in the back...was the car repainted?...2 accidents?...who knows it was major ones or small ones...anyways good luck,
Old May 24, 2005 | 11:49 PM
5 Speed AP2's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (DirtyzGsR_9i6)
Wow, that **** is extremely clean. Shaved emblems too?! Me like.
Old May 24, 2005 | 11:52 PM
thaiphob's Avatar
Nikon!!!
Default Re: Pics and Info bouts a teg I might buy tomorrow... (5 Speed Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, that **** is extremely clean. Shaved emblems too?! Me like.</TD></TR></TABLE>
i noticed that too. for a stock car to not have emblems in the rear usually means it was in somesort of accident, i would check on it tho..
Old May 24, 2005 | 11:59 PM
Freshazzburu's Avatar
That's a good find. Is that dual tips? or am i just too sleepy? Don't be in a rush to buy new rims, all you have to do is take off the center caps and it will look clean
Old May 25, 2005 | 12:12 AM
Deluzional's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (Freshazzburu)
great find, it looks immaculate. But KBB $7700 with 2 accidents under its belt....
Old May 25, 2005 | 12:48 AM
NeaD's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (Deluzional)
Looks clean.
Old May 26, 2005 | 04:58 PM
calxtreme's Avatar
yeah, the saved emblem does probably indicate that it has been hit in the rear. Lift up the trunk mat and board to look at the spare tire well for any damages.
Old May 26, 2005 | 05:31 PM
TegRyder33's Avatar
Default Re: (calxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr_vtc &raquo;</TD></TR><TR><TD CLASS="quote">well since you forgot to include the mileage, if its over 100k i wouldnt get it. this is just my opinion, but that green is ugly as **** with the tan interior. ive seen nice tegs in that color but i dont know. maybe get it to be different. what are your plans for the car? also depends what you feel is right and how long you looked for. i looked for around 4 months before i found the gsr i wanted. good luck and try to work down the price</TD></TR></TABLE>
Green Integra's are nice IMO, I love mine . Looks like a great deal to me, hopefully you'll be driven it off tomorrow night!
Old May 26, 2005 | 06:28 PM
Milanogisser's Avatar
Forgot the mileage???? Hello look at the first line! Almost 89k
Old May 26, 2005 | 06:47 PM
sickofitall1113's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (Milanogisser)
i got my 99 LS for 6400 so i guess that price seems a little high, but if thats what KBB says then go with it. i think it looks good. i also have the tan interior and am not crazy about it but it looks nice and shiny. shiny=
Old May 26, 2005 | 10:12 PM
hadboosttroy's Avatar
Default Re: Pics and Info bouts a teg I might buy tomorrow... (sickofitall1113)
ls's and gsr's are not really comparable in the used car market in my opinion.
Old May 26, 2005 | 11:55 PM
JeffRocksYoSocks's Avatar
Pretty nice, yeah ditch the center caps and they're ok. muffler is tight!!!! syyykkee! i like that green, on bronze, red, white, gunmetal, gold, or black rims is nice.
Old May 27, 2005 | 08:16 PM
cleantegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milanogisser &raquo;</TD></TR><TR><TD CLASS="quote">Forgot the mileage???? Hello look at the first line! Almost 89k </TD></TR></TABLE>
lol i noticed that too. looks like a good car you should offer them $5000 though (accidents), that seems like a fair enough price.
Old May 27, 2005 | 09:34 PM
TurboGS-R's Avatar
I wish mine was "shaved". Actually it is, but I still got those "goofy" holes showing.
Atomic1
Jun 30, 2011 05:05 AM
c1_sleeper
Paint and Body
Aug 22, 2007 09:21 AM
DynastyRacer22
May 6, 2004 11:06 AM
HondaCutter
Oct 10, 2003 09:43 PM
BeeResp0nsible
Mar 1, 2003 10:45 PM
