ITR catback on a EJ8 (pics?)
Old Feb 6, 2002 | 05:04 PM
tFUnK's Avatar
Default ITR catback on a EJ8 (pics?)
has anyone done this conversion? What modifications to the tubing will be needed? and also can somebody post some pics on how it would look? thanks in advance
Old Feb 6, 2002 | 06:53 PM
EH3-R's Avatar
Default Re: ITR catback on a EJ8 (tFUnK)
im wondering the same.....do integra or itr b-pipe fit on a 92-95 hatch?
Old Feb 12, 2002 | 09:23 PM
tFUnK's Avatar
i cant believe nobody has done this
Old Feb 12, 2002 | 09:40 PM
garagespecial
Guest
Posts: n/a
why not just get the muffler and get custom piping?
Old Feb 12, 2002 | 09:46 PM
tFUnK's Avatar
Default Re: ITR catback on a EJ8 (garagespecial)
because people charge like 100 bucks for just the muffler and why not just get the piping with it instead of spending another 200 for custom pipiing?
Old Feb 12, 2002 | 10:40 PM
TurboBumblBee's Avatar
ummm i have tried something very similar..
i tried to put my friends 2000 integra GSR stock exhaust and muffler on my old 92 civic hatchback and the muffler was to big to fit w/ out a lot of modifications.. hope that helps you all..
Old Feb 12, 2002 | 10:50 PM
tFUnK's Avatar
Default Re: ITR catback on a EJ8 (95CivicEX)
ooo i see.. but isnt putting any coupe catback onto a hatch a pain in the rear?
Old May 6, 2007 | 06:31 PM
ricekiller1's Avatar
up...trying to find out about putting a oem ITR catback on my ej8???
Old May 6, 2007 | 06:42 PM
cambopheonix56's Avatar
Default Re: ITR catback on a EJ8 (ricekiller1)
B pipe is different. Not worth it IMO. Just get the muffler.
Old May 7, 2007 | 03:28 PM
Default Re: ITR catback on a EJ8 (cambopheonix56)
what OEM b pipe is the same size(2.5???)_ as the oem itr axle back that i could match it up on my ej8?
Old May 10, 2007 | 05:40 PM
up...^^^^^^^ how is the B pipe differant... ive heard it may be a little to short or long at the cat but the bends are the same???? is that correct?
Old May 10, 2007 | 06:25 PM
SiREJ8's Avatar
I'll post a pic of mine tomorrow if i remember!
the b pipe needs extended, i think 3-4" and so does the the pipe after the muffler!
unless you can get the 4dr itr exhaust which will just bolt on I believe!
Old May 10, 2007 | 08:27 PM
cxSHOE's Avatar
Default Re: ITR catback on a EJ8 (EH3-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH3-R &raquo;</TD></TR><TR><TD CLASS="quote">im wondering the same.....do integra or itr b-pipe fit on a 92-95 hatch?</TD></TR></TABLE>
yes it does...
ok, here we go. ive had this setup for the past 2 years never a problem and everything fit fine. i only had to cut the flange on the cat due to still using my civic exhaust manifold.
d16z6 engine, oem exhaust manifold, to '99 integra ls cat, itr b pipe, to civic spoon n1 muffler
everything fit pefectly fine. i only had to cut and turn the cat flange to meet up with the civic hole placement. if i had a b series engine with an integra exhaust manifold then i wouldnt have to cut anything.
basically if you want to use the itr b pipe on any 92-95 civic you need to use an integra 17" long cat
all 92-01 civic and integra (ls, itr) b pipes are interchangible (as far as pipe fitting under the car).... the problem comes with the cat length. the obd2 integra cats are 17" long civic ones are 15". so its just a matter of choosing the correct combination to fit your 92-01 civic.
Old May 11, 2007 | 02:39 AM
Default Re: ITR catback on a EJ8 (cxSHOE)
well i have a 00 civic ex w/ b18c that has a 4-1 header on it...im waiting for the itr exhaust to arive at acura and i have a crasound cat with the flanges ready to weld on but im waiting to hang the exhaust to see what need to be done...how long the cat needs to be...ect...should i be ok???
1sic95accord
Sep 16, 2018 09:15 PM
mynameizstitch
Jul 9, 2009 10:34 PM
CodyC142
10
Aug 4, 2007 03:44 PM
5spdfrk
Jun 26, 2007 09:59 AM
joneblaze
Feb 27, 2004 10:30 PM
