i got a wiring problems with my 88 civic
i got a 88 civic hb, i swap in a b18a did the wiring. that i got the wiring diagram from from fourthgenerationcivic.com and honda hybrid perf.org started up and it worked but i cant rev over 3.5k the check engine light is throwing 4 and 16. the 16 is not a problem it was my bad. but the 4 is a crank position sensor im pretty sure i wired it right
any suggestion
any suggestion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">if this was a mpfi swap you must have not pinned the distributor, or ecu correct</TD></TR></TABLE>
Most likely since you had to go throught the hassle of wiring for MPFI, which involved the distributor and has as the common problem that you describe is happening.
