new pistons, honeing block?
Old May 24, 2005 | 02:32 PM
91ls-v's Avatar
Default new pistons, honeing block?
well if i was to replace the pistons in my current block do i have to get it honed?
it's a b18a, gonna have pr3 pistons
should i get new wrist pins and piston rings
Modified by 91ls-v at 3:51 PM 5/24/2005
Old May 24, 2005 | 06:01 PM
the g2 teg's Avatar
Default Re: new pistons, honeing block? (91ls-v)
yea get it honed or your rings will not set and you do need new rings and wrist pins
Old May 24, 2005 | 06:39 PM
Yambor's Avatar
Default Re: new pistons, honeing block? (the g2 teg)
Well if you get pr3 pistons from honda or a wholesale honda dealer, they should come with wrist pins.
Yes, get rings. Yes, hone your block.
Its a good idea to purchase .25mm over pistons for your build.
Old May 24, 2005 | 09:46 PM
91ls-v's Avatar
if i go .25 over wouldn't i have to bore out the block...do i have to bring my block to the machine shop to hone it or can i do it myself?
Old May 25, 2005 | 08:03 AM
the g2 teg's Avatar
Default Re: (91ls-v)
its better if you take it to a shop so they will go the same speed up and down if you do you cant control the speed
Ryhaz
10
Jan 14, 2014 07:57 AM
spooncivic1
Nov 23, 2004 03:55 AM
fullracegsr
Feb 23, 2004 05:58 PM
Robban26
15
Jan 24, 2004 01:31 AM
KC GSR
Jun 20, 2002 08:47 AM
