Tranny Noise
Old May 24, 2005 | 01:59 PM
bkray23's Avatar
Default Tranny Noise
2002 Accord 5sp LX, 35,000 miles
Anytime I get to a speed over ~35 MPH there's a loud humming noise that changes pitch with the speed i'm traveling. There are newer tires on the front end, but I dont believe this is tire noise, it seems to be coming from the transmission. I put the car in neutral and the noise does not go away.
Any one know of anything that could be causing problems like this?
Thanks.
Old May 24, 2005 | 03:27 PM
Chiovnidca's Avatar
Default Re: Tranny Noise (bkray23)
Wheel bearing?
Old May 24, 2005 | 03:39 PM
deserthonda's Avatar
rotate tires that way you can eliminate tire noise for sure if problem still there,,,
Old May 24, 2005 | 03:48 PM
SPEED FoRCE's Avatar
if you press the clutch in, does it go away?
Old May 25, 2005 | 02:21 PM
bkray23's Avatar
Default Re: (SPEED FoRCE)
I push the clutch in, and it doesnt do a thing to the noise.
Wheel bearings was one of my idea's but it sounds like it's coming from the midpoint of the car.
It's under the certified pre-owned warranty, so my best bet is to take it in and tell them what's going on.
Tony Cameron
Dec 11, 2013 06:31 AM
lessum
Feb 28, 2010 02:43 PM
gallowmay
Aug 27, 2004 03:58 PM
BigBadBuford
Jan 8, 2004 02:00 PM
Rory Breaker
Mar 17, 2002 12:00 AM
