old lude A motor B20 swap need info
Old May 24, 2005 | 01:54 PM
dirtracer's Avatar
Default old lude A motor B20 swap need info
I have a 2nd gen. lude 87 or 88. Does anyone know if it's a hassell to put in a B20A5 into it because the cables look different than on the A engines.And do you need to buy the master cyl. for the clutch I beleive not. or a link to someplace to get help. the manuals don't really help on this.
Old May 24, 2005 | 02:22 PM
user 9782082308's Avatar
Default Re: old lude A motor B20 swap need info (dirtracer)
You can only fit A series engines without new mounts. If the engine coming out is carb'ed then you'll also have to run new lines and get a fuel pump. The B20a3 or a5's won't work but theres a hybrid B20a~ that uses the same mounts as the A series. Theres some more similarities between the two and some part scavanging has to be done to do a general overhaul.
IslandCivic
15
Nov 14, 2007 02:49 PM
hondahoodlum
Honda Civic (2001 - 2005)
16
Jul 8, 2006 10:37 PM
slipperyduck
Apr 4, 2004 12:39 PM
poop32145432
Mar 2, 2004 02:29 PM
justininhifi
Jun 30, 2003 11:24 AM
