problem
Old Feb 6, 2002 | 04:18 PM
Rob!'s Avatar
Default problem
i have a question...My exhaust pipe on my 91 crx has anti freez coming out of it. its not bad but do you know what the reason why it happens and how to fix it? anything would help...thanks.
Old Feb 6, 2002 | 10:47 PM
Giuseppe's Avatar
Default Re: problem (RaceFacer)
first of all is it antifreeze, or just water drops.......???
if infact it is antifreeze....
what kind of temperatures does your car get to..??????
[QUOTE]exhaust pipe has anti freez coming out of it. its not bad QUOTE]
uhh...yeah.... thats BAD..!!!
get it checked asap, and dont drive around like that any longer..
Old Feb 7, 2002 | 02:47 AM
Rob!'s Avatar
Default Re: problem (Giuseppe)
lol its not bad as in its not pouring out of my pipe. and yes it is antifreez. and my car wasnt evn started when it happened. i was just working on it and as i was pushing the car back a couple feet and a couple drops came out. anyone else?? please help.
Old Feb 7, 2002 | 04:30 AM
4wsB21a's Avatar
New User
do not drive that car. if at any time you have antifreeze in your exhaust, it is not a good thing. unless someone poured the af in your exhaust pipe, then you have a leak, or hole somewhere in the block that has caused the af to get into your exhaust system. i would have it towed to a mechanic and have them totally check everything in the engine to find where it is coming from. (or start by checking the head gasket and block to make sure you have no holes there.)
Old Feb 10, 2002 | 07:12 PM
escocrx's Avatar
Default Re: problem
thats bad REAL BAD. keep driving it to figure it out yourself but i wouldnt. it means u have seapage from yer heads coolin cores. lovely. i wouldnt say its your block. but id check that also.
Old Feb 11, 2002 | 06:53 PM
deepnite's Avatar
see if u have bubbles in ur oil..if u do..then it looks like a headgasket..fix it now befor it blows
Old Feb 11, 2002 | 09:19 PM
RexB16's Avatar
Default Re: problem (deepnite)
yep thats a head gasket, do you feel a loss in power?
Old Feb 11, 2002 | 09:52 PM
RedRacerCivic's Avatar
Default Re: problem (RexB16)
its not bad, its just condensation, my car does the same on certain weather conditions......
Old Feb 11, 2002 | 10:00 PM
RexB16's Avatar
Default Re: problem (RedRacerCivic)
buddy, he said antifreeze not water. last time i check the atmospheric content of the earth does NOT include anitfreeze. either that or he has a problem telling the difference between greenish brown liquid and water.
magicmike23
10
Nov 14, 2010 04:45 PM
Shaynepolevault
Mar 27, 2008 11:43 AM
jdm j
Honda S2000
12
Oct 6, 2007 07:42 AM
H22SiRaccord
Sep 22, 2004 09:25 AM
b16 matt
Jun 16, 2003 05:54 PM
