Keeping cruise control with an aftermarket steering wheel
I'm looking to put an aftermarket setting wheel in my 92 DB1, but I want to keep the factory cruise control. Is there an attachment you can get for the momo hubs that would re-use the factory buttons, or some sort of attachment for any kind buttons. I suppose I could always run some switches to the dash, but I'd like to keep the controls on the wheel.
I looked a long time ago, but couldn't find any switches that would mount like stock on a momo wheel.
you could always make your own switches and drill them into the wheel.. make sure to use the common ground for the switchs on the wheel or else the cruise won't work
I just extended the wires off the Cruise control module and put the buttons near my shifter. Works perfect with my Momo Steering wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakin »</TD></TR><TR><TD CLASS="quote">Then why would Momo offer 2 hubs? They're listed for cruise and non-cruise models?</TD></TR></TABLE>
because if you don't get the right one your horn will not work. You can make it work by wiring up the ground yourself, but it just makes it easier.
I found this:
http://www.shopmomo.com/15ne98.html
Once I see what the hub looks like, I bet I could wire those buttons up to the cruise wires. Might work...
^^ So are the cruise buttons on my teg. I have to turn it on with a button on the dash, but the set/resume/accel etc. buttons on the OEM wheel are momentary.
zenon8890
Jun 7, 2012 03:22 AM
Aodhan
Sep 17, 2007 08:46 AM
Coked GSR
Nov 25, 2006 03:21 PM
Wallace996
Apr 12, 2002 08:43 PM
