obd0 B16 Did a compression test...
Old May 24, 2005 | 09:43 AM
egvtec's Avatar
Default obd0 B16 Did a compression test...
Here she is 140, 130, 120, 130 is that ok? i think i either have a pcv valve problem or a valve seal is leaking. Is this ok compression, i just got her from H motors online last week
Old May 24, 2005 | 11:53 AM
SOHCEK-Turbo's Avatar
Default Re: obd0 B16 Did a compression test... (egvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egvtec &raquo;</TD></TR><TR><TD CLASS="quote">Here she is 140, 130, 120, 130 is that ok? i think i either have a pcv valve problem or a valve seal is leaking. Is this ok compression, i just got her from H motors online last week </TD></TR></TABLE>
No good man return that ****. You should get 180+ across how does it run?
Old May 24, 2005 | 03:08 PM
mmuller's Avatar
Mad Scientist
did you hold the throttle plate open while doing it?
Old May 24, 2005 | 05:32 PM
egvtec's Avatar
ok i must have done it wrong cause i redid it and it was 215 and 220 across the board.
egvtec's Avatar
BTW this time i held the throttle open and unplugged the injector clips
Brandon31386
Jul 23, 2006 10:56 PM
mraudio13
Mar 19, 2006 01:11 PM
Triblade
Feb 21, 2006 06:15 PM
Slammed2K1
Dec 5, 2003 07:35 PM
doublejz
Nov 4, 2003 04:09 PM
