Suspension & Brakes Theory, alignment, spring rates....
which camber kit?
Old May 24, 2005 | 07:40 AM
tegsp's Avatar
Default which camber kit?
I have a da, and I have already decided to get the ingalls kit for the front and back. But now, I dont know which kit with what degree to get. The kit that allows -3/4 to +1 or +1 -1/4 to +3? I am lowered on H&R sports and tokico illuminas. Any help and advice is greatly appreciated.
Old May 24, 2005 | 09:18 AM
tegsp's Avatar
Default Re: which camber kit? (tegsp)
bump
Old May 24, 2005 | 09:51 AM
nonsense's Avatar
I guess it depends on how much camber you want to end up with. If you want exactly zero camber, then +1 probably won't be enough correction and you'll want the +3 kit. If you just want to get the two sides even, but still maintain some negative camber, then the -3/4 to +1 should be fine.
Old May 24, 2005 | 01:56 PM
tegsp's Avatar
Default Re: which camber kit? (nonsense)
what would be the advantage of having some negative camber, and which would wear faster, having it on 0 or having a little negative camber?
Old May 24, 2005 | 03:29 PM
tegsp's Avatar
bump for help
Old May 24, 2005 | 03:36 PM
nonsense's Avatar
a little negative camber isn't going to wear out your tires in any noticable way. As long as you have an alignment done after making any changes to the suspension your tires should wear evenly (incorrect toe settings cause tires to wear out fast).
The advantage of more negative camber is better handling.
Old May 24, 2005 | 03:50 PM
tegsp's Avatar
if I got the +3 kit, would it still allow me to have a little negative camber?
Old May 24, 2005 | 05:29 PM
CivicMike's Avatar
yes, lowering your car is gonna give you negative camber which you need to take out with the camber kit......you can leave a little in though.
Old May 25, 2005 | 06:39 AM
tegsp's Avatar
Default Re: (CivicMike)
aight, I think thats all the info I needed, thanks for the replies guys.
91EF919
15
Jun 24, 2009 07:15 AM
kasperxtcy
Suspension & Brakes
Nov 6, 2007 10:19 AM
crx1009
Apr 5, 2006 09:57 AM
toooslow
May 7, 2003 12:38 PM
InfamousRS
Feb 14, 2002 07:31 AM
