Honda S2000 Honda S2000
Transmission Problems
Old May 24, 2005 | 07:20 AM
ExtremePowerOuters's Avatar
Default Transmission Problems
I am having this transmission problem with my S2000. When I am in NEUTRAL and I push the clutch in and out I have this thumping sound coming from the rear, and the car jerks a tiny bit. Another problem is when in reverse, it is not running smooth, it takes more throttle to move, and also makes odd noises and has an odd feeling to it (sometimes doesnt want to come out of the gear). Another related issue is I cannot CANNOT get into 1st gear when the car is rolling. As in, I cant downshift to first when im moving. Anyone know what this is? I am going to get it fixed, but want a idea before I turn it to Honda.
Old May 24, 2005 | 07:55 AM
fknfast's Avatar
Default Re: Transmission Problems (ExtremePowerOuters)
throw out bearing issue maybe.. the input shaft isnt lubed enough and the TOB sticks sometimes. as for the rear end noise when in neutral ??
Old May 24, 2005 | 07:56 AM
Default Re: Transmission Problems (fknfast)
Hmmm....Im confused about this whole mess.
Old May 24, 2005 | 07:59 AM
fknfast's Avatar
is the car stock?
Old May 24, 2005 | 08:00 AM
Yes its completely stock.
Old May 24, 2005 | 08:05 AM
fknfast's Avatar
take it in hopefully they dont bust your ***** over it.
Old May 24, 2005 | 08:06 AM
I have extended warranty with it. I wont if that will be covered.
Old May 24, 2005 | 02:44 PM
92jdmhatch's Avatar
use ur extended warranty....i blew my motor with a turbo on there.....took the turbo off and claimed an engine problem...at first they did not want to cover the motor.....but after fighting with them back and forth....i got the job done...but my extended warranty was not through honda
Old May 24, 2005 | 02:46 PM
Default Re: Transmission Problems (92jdmhatch)
Mine is through Nissan. I took the car in, and they are trying to figure whats wrong first. Once they know they are going to tell me. They said tommorow morning.
ef_dx_90
Oct 22, 2009 09:02 PM
spammy123
Honda Civic (2006 - 2015)
11
Dec 3, 2007 12:11 PM
Redirwol1
Honda S2000
Jan 23, 2006 12:32 AM
vtek4life
Mar 24, 2004 03:37 PM
