any ideas on how to get ceramic coating off header?
Old May 24, 2005 | 04:45 AM
EFB16ACRX
Guest
Posts: n/a
Default any ideas on how to get ceramic coating off header?
well, i have to weld another o2 bung into my dc header, which is ceramic coated, and i need to get the ceramic off to weld the bung on. any ideas?
Old May 24, 2005 | 05:43 AM
Brownjd's Avatar
Default Re: any ideas on how to get ceramic coating off header? (EFB16ACRX)
just drill it. start with a small bit and work your way up to the right size
Old May 24, 2005 | 05:47 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: any ideas on how to get ceramic coating off header? (Brownjd)
i want it to last. think the pipe is thick enough for it?
Modified by EFB16ACRX at 9:59 AM 5/24/2005
Old May 24, 2005 | 05:59 AM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFB16ACRX &raquo;</TD></TR><TR><TD CLASS="quote">i want it to last. think the pipe is thick enough for it?</TD></TR></TABLE>
if whoever welds it does a good job
Old May 24, 2005 | 06:00 AM
EFB16ACRX
Guest
Posts: n/a
ok cool. i just dont really see taht working, because it would still be welding to the ceramic wouldnt it? or maybe im stupid. i dont nkow.
Old May 24, 2005 | 06:04 AM
EP3_05's Avatar
Grind off the ceramic coating where you will install the bung. Drill the hole for the bung using successively larger bits until you get the right dimension. Then weld the bung to the bare steel. Done
Old May 24, 2005 | 06:06 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: any ideas on how to get ceramic coating off header? (91civic)
ok, i tried just sanding it off, but that obviously didnt work, i jsut wanted some other ideas. thanks.
Old May 24, 2005 | 06:07 AM
EP3_05's Avatar
Sanding it by hand is really not going to work that well and will take a long time. Try a power grinding wheel.
Old May 24, 2005 | 06:21 AM
thatbluecrx's Avatar
just wait a year and itll rust off
or like the others said a die grinder or something will easily take it off
Old May 24, 2005 | 06:23 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: any ideas on how to get ceramic coating off header? (thatbluecrx)
haha, thanks guys, i just was kinda worried about taking a grinder to my header. but ill be careful
Old May 25, 2005 | 03:57 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">just wait a year and itll rust off </TD></TR></TABLE>
That's for sure. Coatings are crap.
Old May 25, 2005 | 04:54 AM
Default Re: any ideas on how to get ceramic coating off header? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
That's for sure. Coatings are crap.</TD></TR></TABLE>
they sure are...
but they really do reduce bay temps drastically(while its still on lol)
Old May 26, 2005 | 03:12 AM
they sure are...
but they really do reduce bay temps drastically(while its still on lol)</TD></TR></TABLE>
I don't know about that. Regardless, uncoated stainless steel keeps temperatures lower due to its low thermal conductivity.
X2BOARD
40
May 27, 2009 09:15 PM
ILcrxsi1
10
Jan 7, 2007 06:31 PM
db8gsr_teg
Mar 16, 2006 10:05 AM
atmosphere
Jan 21, 2006 12:36 AM
Synergy001
13
Sep 3, 2003 11:13 AM
