need info on the studs that go through the valve cover
Old May 23, 2005 | 09:32 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default need info on the studs that go through the valve cover
i striped one of the studs when i changed the valve cover gasket i think cuz i turn it and turn it and it wont tighten and it wont come loose but it wont pull out is this easily replaced or am i goin to have trouble?
Old May 24, 2005 | 04:32 AM
Monkey Fing a Coconut's Avatar
Default Re: need info on the studs that go through the valve cover (raylude)
easy replace, cut the nut off, get a stud remover, get a new stud, insert new stud
Old May 24, 2005 | 05:52 AM
Greyout's Avatar
Default Re: need info on the studs that go through the valve cover (twistedbydezign)
I am pretty sure you just need a deep socket to get them out once the valvecover is off
Old May 24, 2005 | 10:49 AM
raylude's Avatar
Default Re: need info on the studs that go through the valve cover (Greyout)
i was lookin in majestic honda i cant find the bolt by its self where can i find one?
Old May 24, 2005 | 10:50 AM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">i was lookin in majestic honda i cant find the bolt by its self where can i find one?</TD></TR></TABLE>
local dealership?
Old May 24, 2005 | 11:28 AM
Hawkze_2.3's Avatar
You need to try looking harder---&gt;http://www.hondaautomotivepart...82%29
#'s 14 and 15
Old May 24, 2005 | 11:44 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure you just need a deep socket to get them out once the valvecover is off</TD></TR></TABLE>
Yeah, no stud remover or anything like that. Just a deep socket.
Old Jun 6, 2005 | 04:44 AM
raylude's Avatar
Default Re: need info on the studs that go through the valve cover (Hawkze_2.3)
are they all the same? the one i broke is the one that goes to the far left between the cams where the wires go over it
Old Jun 6, 2005 | 05:11 AM
Jagan'92's Avatar
Aaargh, I broke one of mine this weekend doing a valve job. Those damn things - it says 9 ft-lbs. I knew they broke easy, and I've always just done them by hand. This time I decided to use the torque wrench, man I'm a moron.
Luckily mine is the one in the center, and it broke flush with the valve cover. I'm still driving it around, and there's no leakage. Still needs to be fixed though.
Old May 25, 2007 | 08:36 AM
plikit's Avatar
Default need some info tooo
does arp make valve cover studs for the prelude? im looking thru their catalog and i have no idea what size or anything. am i better off getting a set from the dealer? 3 of my are stripped...
http://www.arp-bolts.com/Catalog/Catalog.html ?
Old May 25, 2007 | 09:26 AM
Maharajamd's Avatar
9lbs? I thought the stud gets 9lbs and the nuts get 7.
Has everyone with a prelude fell victim to these bolts...lord knows I did..
Old May 25, 2007 | 01:49 PM
mattsnooz's Avatar
Default Re: (Maharajamd)
dealer anything costs an arm and a leg
they wanted 69 dollers for a powersteering belt.
the pump rebuild from a1cardone is only 89 dollers with core. (belts almost as much as pump)(oh yeah pump from dealer 269 oem acdelco Not installed)
whats that like 200% + markup?
Old May 25, 2007 | 04:02 PM
esedulerp5tenin's Avatar
Default Re: need some info tooo (plikit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">Aaargh, I broke one of mine this weekend doing a valve job. Those damn things - it says 9 ft-lbs. I knew they broke easy, and I've always just done them by hand. This time I decided to use the torque wrench, man I'm a moron.
Luckily mine is the one in the center, and it broke flush with the valve cover. I'm still driving it around, and there's no leakage. Still needs to be fixed though.</TD></TR></TABLE>
hahaahhaaa i did the EXACT same thing last week too.
called honda dealer, $6 for both the stud and nut. not bad.
only thing i'm worried about is oil getting into cyl #2 and 3 spark plug holes
Old Sep 25, 2009 | 04:24 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Yup, i am a victim of those damm studs. 3 hours ago i was putting my damm valve cover back on and SNAP ****er broke. Anyway when dealing with valve cover bolts be GENTLE!!!
Xcuse me for bringing this thread from the dead
jwicecold
Nov 1, 2008 01:02 AM
saddler263
12
Aug 28, 2008 10:08 AM
95greenteg
Jan 31, 2006 07:01 AM
Junkyard2000
15
Jan 23, 2006 06:29 PM
Gimpo
Oct 9, 2004 01:57 PM
