what is the proper Offset for aftermarket wheels?
Old May 23, 2005 | 05:50 PM
B16CRXT's Avatar
Default what is the proper Offset for aftermarket wheels?
I'm looking to buy a set of rota attacks, but Im not sure what offset to choose. What does the offset determine and what should I choose? They offer 40, 45 and 48. I would liek to put 205/55 tires on them.
TIA,
Chris
Old May 23, 2005 | 06:55 PM
Turbo88hatch's Avatar
Default Re: what is the proper Offset for aftermarket wheels? (B16CRXT)
I'm runnin 205/45 with a 40mm offset
Old May 23, 2005 | 08:06 PM
B16CRXT's Avatar
Default Re: what is the proper Offset for aftermarket wheels? (Turbo88hatch)
Does it rub at all?
I would like to lower it about 2" after teh new rims. I currently have 17" Shu's with 205/50.
Old May 24, 2005 | 06:23 PM
B16CRXT's Avatar
anyone else? what is the science behind the offset?
Old May 24, 2005 | 09:19 PM
XrcR6's Avatar
http://www.tirerack.com/wheels/tech/offset.jsp
Old May 25, 2005 | 03:22 AM
Targa250R's Avatar
be professional
For a 7" wide wheel, you'll want no less than a +40 offset. +45 would also work.
Do not use 205/55 tires with 15" or 16" wheels, the outer diameter will be too large. Stick with a 195/50 or 205/50 for 15", and 205/40 or 205/45 for 16".
Old May 25, 2005 | 01:01 PM
B16CRXT's Avatar
Default Re: what is the proper Offset for aftermarket wheels? (Targa250R)
well, I have 205/50 on my 17's currently. When you say the outer diameter would be too large...are you saying it would rub with a 55 profile on 15" wheels?
Old May 25, 2005 | 03:12 PM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">well, I have 205/50 on my 17's currently. When you say the outer diameter would be too large...are you saying it would rub with a 55 profile on 15" wheels?</TD></TR></TABLE>
might not rub, but it's taller than stock and will hurt performance.
i can't believe you fit 205/50/17's with no rubbing
i opted for a +40mm offset for 16", looks perfect to me
labatia
Jul 14, 2004 01:28 PM
^jefs0ng
Jan 1, 2004 07:17 PM
MRDC2
Feb 21, 2003 05:33 PM
friedsqrl
Jan 29, 2002 07:44 PM
deepnite
Dec 19, 2001 09:54 AM
