Thinking of chipping/converting to obd1. What should I do?
Old May 23, 2005 | 04:17 PM
HoUTX98GSR's Avatar
Default Thinking of chipping/converting to obd1. What should I do?
I just recently bought a 98 gsr with ctr cams and a 4-1 header. The new cams make the car sluggish when the vtec engages at 4400 rpm. The vtec engagement needs to be moved upward. I bought a fields contoller off of ebay and got ripped $118 bucks cuz the ******* sent me a fried unit and wouldnt warranty . So now im thinking instead i would maybe i would just chip the ecu. can you chip an obd2 ecu? What ecu's could i use? i know that if i get a p72 ecu from a 94 it would be obd1 and i could get the conversion harness. but what about a chip? i cant afford to go hondata or anything and i think ive decided not to use piggyback. Really the only thing im looking for is smooth vtec engagement and properly working secondaries .
any suggestions?
Old May 23, 2005 | 04:58 PM
HoUTX98GSR's Avatar
Default Re: Thinking of chipping/converting to obd1. What should I do? (HoUTX98GSR)
bump
Old May 23, 2005 | 07:21 PM
HoUTX98GSR's Avatar
bump again...
im new at ecu's/chipping ect... someone help
Old May 23, 2005 | 07:55 PM
CNSK's Avatar
just run a obd2b (i think for 98+, someone correct) conversion and run a stock p72 gsr ecu obd1.....
Old May 23, 2005 | 08:13 PM
HoUTX98GSR's Avatar
Default Re: Thinking of chipping/converting to obd1. What should I do? (CNSK)
well actually its obd2a and what about the vtec engagement? i want it to be at about 5600-5700.
Old May 23, 2005 | 09:20 PM
iloveboys's Avatar
what intake manifold are you running? if stock, id use the jumper harness and the obd 1 ecu. if you are using something that doesnt have secondary runners, like the skunk2, then id use a chipped obd1 p28. i have never heard of anyone chipping a obd 2 ecu though.
Old May 23, 2005 | 09:39 PM
HoUTX98GSR's Avatar
Default Re: Thinking of chipping/converting to obd1. What should I do? (iloveboys)
yes... im using the stock manifold... i KNOW the best thing to do would be use the 94-95 obd1 p72 gsr ecu! but what would be the best way to handle the vtec engagement? and if the answer is "chip it", then would getting an ecu other than the p72 benefit me any? anyone else?
Old May 23, 2005 | 09:47 PM
iloveboys's Avatar
the answer is not to chip it. if you chip it, the vtec engagement will be preprogrammed. you should get a vafc or some kind of vtec controller therefore you will be able to find the "sweet" spot for your setup when you dyno. you can also use your butt dyno but thats really hard to say if you are truely making hp or not.
Old May 24, 2005 | 02:06 AM
no2unenolife's Avatar
get an obd1 ecu, obd2a to obd1 conversion harness. Uberdata is a good way to start. i'm learning my self, you'll seen a chip burner, and some soldering skills.
check out the uberdata forums. for more info
or find people to do it for u, around 70 bux
like phearable.net
JerseySiPOS
Feb 18, 2009 04:31 AM
dsmh8tr
Aug 27, 2008 07:13 PM
Neptronix
12
Jan 25, 2008 08:06 AM
rwlangdale
Jan 4, 2008 10:01 PM
yellowbuffalo
Jun 4, 2003 06:44 PM
